[gdal-dev] PROJ context and threads
Even Rouault
even.rouault at spatialys.com
Wed Apr 28 06:38:51 PDT 2021
We could have a OSRSetAutoclosePROJDatabase() global function that would
call proj_context_set_autoclose_database() when it creates the
per-thread PROJ context
==> ogr/ogr_proj_p.cpp
An alternative would be to enhance PROJ to have a mode where the SQLite3
db handle would be shared amongst several contexts. In theory that could
be possible as you can invoke sqlite3_open_v2() with
SQLITE_OPEN_FULLMUTEX. But would require non completely trivial changes
Le 28/04/2021 à 15:30, Andrew Bell a écrit :
> On Tue, Apr 27, 2021 at 11:44 PM Alan Snow <alansnow21 at gmail.com
> <mailto:alansnow21 at gmail.com>> wrote:
> By default pyproj uses the autoclose option and provides this
> option for users who want better performance and know they have a
> single threaded application:
> https://pyproj4.github.io/pyproj/stable/api/global_context.html
> <https://pyproj4.github.io/pyproj/stable/api/global_context.html>
> Thanks for this! But it appears that the PROJ context held by a
> thread using GDAL is private, so I don't think I can call
> proj_context_set_autoclose_database(). I think I'm going to have to
> make sure that the thread actually terminates in order to release the
> context.
> If someone has other suggestions, I'd be happy to hear them.
> Andrew Bell
> andrew.bell.ia at gmail.com <mailto:andrew.bell.ia at gmail.com>
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210428/b89a791f/attachment-0001.html>
