[gdal-dev] Reading from PNG file in Java from using GDAL
paul.malm at lfv.se
paul.malm at lfv.se
Wed Aug 18 00:17:17 PDT 2021
Yes I have gt-epsg-hsql (version 20.2)
-----Ursprungligt meddelande-----
Från: Brad Hards <bradh at frogmouth.net>
Skickat: den 18 augusti 2021 07:52
Till: gdal-dev at lists.osgeo.org
Kopia: Malm, Paul (Operations AIM) <paul.malm at lfv.se>
Ämne: Re: [gdal-dev] Reading from PNG file in Java from using GDAL
Klicka bara p? l?nkar och ?ppna bilagor om du litar p? avs?ndaren och vet att inneh?llet ?r s?kert.
On Wednesday, 18 August 2021 3:24:27 PM AEST paul.malm at lfv.se wrote:
> The problem is reading "GridCoverage2D" from the reader "cov =
> reader.read(null);", where it breaks. It works with the original TIF-file.
> The program breaks here:
> java.awt.geom.affineTransform.class (public
> AffineTransform(AffineTransform
> Tx) { this.m00 = Tx.m00; ) I have the gt-image module and matching
> .wld, .prj and .png.aux.xml files.
What is the exception?
Do you have a referencing jar loaded (or in the classpath) - something like gt-epsg-hsql ?
Brad
