[gdal-dev] Windows build errors GDAL 3.3.1
Even Rouault
even.rouault at spatialys.com
Wed Aug 18 16:24:54 PDT 2021
Craig,
did you update an existing git checkout ? If so, due to the lack of
header dependency tracking in our nmake & GNUmakefile build systems, you
generally have to "nmake /f makefile.vc clean" (or "make clean" on Unix)
before rebuilding.
Even
Le 19/08/2021 à 01:21, Craig Delancy a écrit :
> When pulling and building the latest release from GitHub, there are
> several unresolved externals that halt the build.
> 1> Creating library gdal_translate.lib and object gdal_translate.exp
> 1>gdal_d.lib(eedacommon.obj) : error LNK2019: unresolved external
> symbol "bool __cdecl CPLIsMachinePotentiallyGCEInstance(void)"
> (?CPLIsMachinePotentiallyGCEInstance@@YA_NXZ) referenced in function
> "protected: char * * __cdecl
> GDALEEDABaseDataset::GetBaseHTTPOptions(void)"
> (?GetBaseHTTPOptions at GDALEEDABaseDataset@@IEAAPEAPEADXZ)
> 1>gdal_d.lib(gdalhttp.obj) : error LNK2019: unresolved external symbol
> "void * __cdecl CPLHTTPSetOptions(void *,char const *,char const *
> const *)" (?CPLHTTPSetOptions@@YAPEAXPEAXPEBDPEBQEBD at Z) referenced in
> function "void __cdecl WMSHTTPInitializeRequest(struct WMSHTTPRequest
> *)" (?WMSHTTPInitializeRequest@@YAXPEAUWMSHTTPRequest@@@Z)
> "void * __cdecl CPLHTTPIgnoreSigPipe(void)"
> (?CPLHTTPIgnoreSigPipe@@YAPEAXXZ) referenced in function "enum CPLErr
> __cdecl WMSHTTPFetchMulti(struct WMSHTTPRequest *,int)"
> (?WMSHTTPFetchMulti@@YA?AW4CPLErr@@PEAUWMSHTTPRequest@@H at Z)
> "void __cdecl CPLHTTPRestoreSigPipeHandler(void *)"
> (?CPLHTTPRestoreSigPipeHandler@@YAXPEAX at Z) referenced in function
> "enum CPLErr __cdecl WMSHTTPFetchMulti(struct WMSHTTPRequest *,int)"
> 1>gdal_translate.exe : fatal error LNK1120: 4 unresolved externals
> 1>NMAKE : fatal error U1077: 'cl' : return code '0x2'
> 1>Stop.
> Is it possible I have misconfigured something in the build process?
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210819/334383de/attachment.html>
