[gdal-dev] Custom vertical transformations
Even Rouault even.rouault at spatialys.com
Fri Aug 20 08:30:17 PDT 2021
> Regarding your immediate issue, the workaround I see would be that you
> use PROJ to create a regular grid that contains the vertical
> correction, use gdalwarp to transform it to the exact extent and
> resolution of the result of your 2D-only gdalwarp, and finally use
> gdal_calc to sum the two.
Well, if you actually create a vertical correction only grid, then you
could just use  -s_srs "+proj=longlat +ellps=...
+geoidgrids=your_tif_or_gtx"  (or maybe as output, or fix the sign of
the correction in the grid), since the workaround I give above is what
gdalwarp would do. But of course none of this will solve the
time-dependent aspect you need.
http://www.spatialys.com
