[gdal-dev] How to handle private (system) tables which a caller may explicitly want
Even Rouault
even.rouault at spatialys.com
Sun Aug 22 01:59:41 PDT 2021
Hi Nyall,
There are several possible approaches to this:
- have a LIST_ALL_TABLES=YES open option. A few drivers expose it, like
PG, SQLite and GPKG. But the intent here was more for drivers that use
by default the content of a geometry_columns table to establish their
list of layers. With LIST_ALL_TABLES=YES they expose also other
non-spatial tables. But if that includes "system" tables or not is
driver dependent. I see the GPKG driver still hides system tables,
whereas SQLite really shows all tables, and PG exposes for example
raster tables (but not pg_XXXX tables, but I don't think they are actual
tables, so that might explain it)
- have a GetLayerByName() implementation that creates on-demand layers.
This is implement, among other, for example in the SQLite driver. In
that case, those new layers must be added to the layer list (ie freeing
them is done by the driver at dataset closing)
- or just rely on ExecuteSQL("SELECT * FROM the_table"). This generally
works for most drivers without adding new code, and from a quick test,
this works with the PGeo driver. Except that MDBTools emits errors on
the console when trying on a non-existing table. I guess some quick
processing of the SQL string could be done to extract the table name,
check if it exists and it it doesn't just emits a OGR error. Or have a
special handling of a "SELECT * FROM "_ogr_table_list_" " that would
return them ?
Even
Le 22/08/2021 à 06:33, Nyall Dawson a écrit :
> Hi list,
> Looking for some advice here on the best way to handle a particular
> situation in some particular GDAL formats, specifically formats which
> have a bunch of internal or system tables which we don't want to
> expose to users in 99.99999% of cases BUT still allowing the 0.000001%
> to explicitly get access to the tables when needed.
> An example: the ESRI personal geodatabase format has a bunch of tables
> like "GDB_Annosymbols", "GDB_Relationships", "GDB_TopoRules", etc. In
> almost all cases a user won't want to see these tables exposed from
> client applications so they are currently hardcoded to be skipped over
> when building the list of layers for a datasource. BUT there's
> actually some useful content in these tables which an application
> might want to read in very specific cases, e.g. if the application
> wanted to read the topo rules to convert these to a human readable
> form, or the relationship information, etc.
> I can't see any way to handle this in current GDAL api -- either a
> layer is exposed and accessible or it's skipped and there's no way for
> a client to access it. Am I missing something, or would this require
> new API? If so, has anyone any thoughts on how these could be handled
> nicely?
> Nyall
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
