[gdal-dev] NITF DES
Even Rouault even.rouault at spatialys.com
Tue Aug 24 09:50:14 PDT 2021
Hello,
yes, first look:
- at the doc of the DES creation option in
https://gdal.org/drivers/raster/nitf.html#creation-issues
- at
https://gdal.org/drivers/raster/nitf_advanced.html#data-extension-segments-xml-des
you will need to compose the DES segment in a relatively low level.
Look at examples in :
https://github.com/OSGeo/gdal/blob/de6a6b44302be5c6a294d86f6ca35ebcdce563ff/autotest/gdrivers/nitf.py#L3728
https://github.com/OSGeo/gdal/blob/de6a6b44302be5c6a294d86f6ca35ebcdce563ff/autotest/gdrivers/nitf.py#L3795
Note: gdal.EscapeString(des_data, gdal.CPLES_BackslashQuotable) with
binary data only works since a commit done yesterday in GDAL master!
If using an older version, backslash escaping can be done with :
escaped_data = data.replace(b'\\', b'\\\\').replace(b'\0', b'\\0') \
                    .replace(b'\"', b'\\"').replace(b'\n', b'\\n')
Best regards,
Even
Le 24/08/2021 à 18:45, ni hao a écrit :
> Hi List,
> Is there a GDAL utility or Python code to delete/alter/write to NITF
> Data Extension Segments (DES) ?
> Thanks.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210824/a5f0f63f/attachment.html>
