[gdal-dev] NITF DES
ni hao
ni_hao88 at hotmail.com
Wed Aug 25 09:57:44 PDT 2021
Thank you Even for your help.
Sent: August 24, 2021 3:28 PM
To: ni hao <ni_hao88 at hotmail.com>; gdal-dev at lists.osgeo.org <gdal-dev at lists.osgeo.org>
Subject: Re: [gdal-dev] NITF DES
Le 24/08/2021 à 20:07, ni hao a écrit :
Hi Even,
Thank you for your reply.
Is there a simpler example to remove DES (say DES ID = 1) from an existing NITF, or replace DES with a null string?
No, there's no code to update/remove a DES . You'll need to edit the file at byte level, or rewrite a new one without them
From: Even Rouault <even.rouault at spatialys.com><mailto:even.rouault at spatialys.com>
Sent: August 24, 2021 1:50 PM
To: ni hao <ni_hao88 at hotmail.com><mailto:ni_hao88 at hotmail.com>; gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org> <gdal-dev at lists.osgeo.org><mailto:gdal-dev at lists.osgeo.org>
Hello,
yes, first look:
- at the doc of the DES creation option in https://gdal.org/drivers/raster/nitf.html#creation-issues
- at https://gdal.org/drivers/raster/nitf_advanced.html#data-extension-segments-xml-des
you will need to compose the DES segment in a relatively low level.
Look at examples in :
- https://github.com/OSGeo/gdal/blob/de6a6b44302be5c6a294d86f6ca35ebcdce563ff/autotest/gdrivers/nitf.py#L3728
- https://github.com/OSGeo/gdal/blob/de6a6b44302be5c6a294d86f6ca35ebcdce563ff/autotest/gdrivers/nitf.py#L3795
Note: gdal.EscapeString(des_data, gdal.CPLES_BackslashQuotable) with binary data only works since a commit done yesterday in GDAL master!
If using an older version, backslash escaping can be done with :
escaped_data = data.replace(b'\\', b'\\\\').replace(b'\0', b'\\0') \
.replace(b'\"', b'\\"').replace(b'\n', b'\\n')
Best regards,
Even
Le 24/08/2021 à 18:45, ni hao a écrit :
Hi List,
Is there a GDAL utility or Python code to delete/alter/write to NITF Data Extension Segments (DES) ?
Thanks.
gdal-dev mailing list
https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210825/48dff8da/attachment.html>
