[gdal-dev] On Internal PROJ When Building
Even Rouault
even.rouault at spatialys.com
Thu Aug 26 09:51:51 PDT 2021
Le 26/08/2021 à 18:33, Patrick Young a écrit :
> Thanks Even!
> As newer versions of Ubuntu pick up fresher versions of proj (was
> checking out https://packages.ubuntu.com/groovy/libproj-dev
> <https://packages.ubuntu.com/groovy/libproj-dev>), is there a minimum
> version of proj that'll be reasonable (e.g. 7 or 8) to use?
The latest PROJ version you can use, the better. At some point I can
imagine we might want to drop the 6.x series for example. I guess we
must wait at least for the next Ubuntu LTS for that.
Even
http://www.spatialys.com
