[gdal-dev] GeoRSS AUTHOR_NAME option
Even Rouault even.rouault at spatialys.com
Fri Aug 27 03:10:14 PDT 2021
Andrea,
the driver documentation indicates that AUTHOR_NAME is only used for
Atom format output, and that by default the driver uses the RSS format,
so this behaves as expecte
Even
Le 27/08/2021 à 11:31, andy a écrit :
> Hi,
> if I use AUTHOR_NAME option, I have no element in the XML header.
> Starting in example from this CSV
> |description,link,pubDate,title,guid a
> description,https://lorem.com/1431092533786918915,2021-08-27T03:13:43Z,a
> <https://lorem.com/1431092533786918915,2021-08-27T03:13:43Z,a>
> title,https://lorem.com/1431092533786918915
> <https://lorem.com/1431092533786918915> |
> and running
> |ogr2ogr -f geoRSS -dsco TITLE="header title" -dsco
> LINK="https://lorem.com/feed.xml <https://lorem.com/feed.xml>" -dsco
> DESCRIPTION="header description" -dsco AUTHOR_NAME="The great author"
> -dsco USE_EXTENSIONS="YES" tmp.xml tmp.csv -oo AUTODETECT_TYPE=YES |
> I have this
> |<?xml version="1.0"?> <rss version="2.0"
> xmlns:georss="http://www.georss.org/georss
> <http://www.georss.org/georss>"> <channel> <title>header title</title>
> <description>header description</description>
> <link>https://lorem.com/feed.xml <https://lorem.com/feed.xml></link>
> <item> <description>a description</description>
> <link>https://lorem.com/1431092533786918915
> <https://lorem.com/1431092533786918915></link> <pubDate>Fri, 27 Aug
> 2021 03:13:43 GMT</pubDate> <title>a title</title>
> <guid>https://lorem.com/1431092533786918915
> <https://lorem.com/1431092533786918915></guid> </item> </channel> </rss> |
> I’m using GDAL 2.4.4, released 2020/01/08. Do I have this problem due
> to this old version?
> Thank you
> ___________________
> Andrea Borruso
> website: https://medium.com/tantotanto <https://medium.com/tantotanto>
> 38° 7' 48" N, 13° 21' 9" E, EPSG:4326
> ___________________
> "cercare e saper riconoscere chi e cosa,
>  in mezzo all’inferno, non è inferno,
> e farlo durare, e dargli spazio"
> Italo Calvino
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210827/213b9c63/attachment-0001.html>
