[gdal-dev] Crash on cancel overviews creation
Javier Jimenez Shaw
j1 at jimenezshaw.com
Fri Aug 27 06:56:56 PDT 2021
Thanks Even
We tested your patch and we were not able to crash it. It looks like fixed
.___ ._ ..._ .. . ._. .___ .. __ . _. . __.. ... .... ._ .__
Entre dos pensamientos racionales
hay infinitos pensamientos irracionales.
On Thu, 26 Aug 2021 at 19:02, Even Rouault <even.rouault at spatialys.com>
wrote:
> Javier,
> Hopefully https://github.com/OSGeo/gdal/pull/4347 should solve that
> Even
> Le 26/08/2021 à 18:45, Javier Jimenez Shaw a écrit :
> Hi
> Some times (unfortunately it is not reproducible every time) we got a
> crash when we cancel the overview generation.
> I tried to reproduce it in my Ubuntu 20.04, but couldn't. My colleagues
> are able to reproduce some times on Mac and Windows.
> In C++, with GDAL 3.3.1, calling BuildOverviews("AVERAGE", ...) to produce
> embedded overview and calling the cancel callback, it crashes on
> overviews.cpp:
> ~PointerHolder() { CPLFree(ptr); }. (line 3929)
> The reason of the crash is : Thread 34: EXC_BAD_ACCESS (code=1,
> address=0x1d)
> Yes, the debugger says the value of "ptr" is 0x1d... that does not make so
> much sense.
> the debugger shows this steps on the back trace:
> poJob->oDstBufferHolder.reset(new PointerHolder(poJob->pDstBuffer));
> (line 4930)
> GDALRegenerateOverviewsMultiBand (line 4638)
> Before calling to BuildOverviews I am calling
> CPLSetConfigOption("GDAL_NUM_THREADS", "ALL_CPUS");
> to make it multithreaded.
> The image is an RGBA 8bit with JPEG compression.
> Is anything wrong there?
> Thanks.
> gdal-dev mailing listgdal-dev at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/gdal-dev
> -- http://www.spatialys.com
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210827/20790c06/attachment.html>
