[gdal-dev] WFS Vector Layer Improvement
aharon david
aharond11 at gmail.com
Sat Aug 28 23:06:33 PDT 2021
I want to suggest an improvement in WFS Vector Layer.
my suggestion is just to remove the lines 839 and 840:
osURL = CPLURLAddKVP(osURL, "TYPENAME", nullptr);
osURL = CPLURLAddKVP(osURL, "TYPENAMES", nullptr);
in file: "gdal-3.3.1\ogr\ogrsf_frmts\wfs\ogrwfsdatasource.cpp".
The big advantage is that the GetCapabilitiy Response will be minimal and
contain info only
for the layers that are set in the tag - TYPENAME in case it is placed in
the pszBaseURL.
There is no disadvantage to this change.
There is no change in the function behavior.
THanks.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210829/049fbfb3/attachment.html>
