[gdal-dev] Lossless JPEG2000 compression with NITF Format and OpenJPEG
Even Rouault even.rouault at spatialys.com
Mon Aug 30 08:21:05 PDT 2021
yes, in the 3.3 branch and earlier, there was no tunable to ask for
lossless JPEG2000 compression
If you use GDAL master, you can now use the
PROFILE=NPJE_NUMERICALLY_LOSSLESS option for that
Even
Le 30/08/2021 à 17:16, Chastain, Raymond Lee (MU-Student) a écrit :
> We're trying to create NITFs with lossless compression using the
> OpenJPEG driver for JPEG2000 compression.
> We've set the "QUALITY=100" creation option but are still noticing
> that repeated conversions generate different perceptual image hashes.
> The OpenJPEG driver mentions "REVERSIBLE=YES" but that doesn't seem to
> be a valid creation option for the NITF driver.
> Sample gdal_translate command:
> "gdal_translate -of NITF -co IC=C8 -co BLOCKXSIZE=256 -co
> BLOCKYSIZE=256 -co SDE_TRE=YES -co QUALITY=100 sample.tif reversible.nitf"
> Am I going about this the right way?
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210830/8ccc7cb2/attachment-0001.html>
