[gdal-dev] subdatasets of
Michael Sumner
mdsumner at gmail.com
Tue Aug 31 03:31:29 PDT 2021
Excellent, thanks so much it's definitely not GDAL-related, a surprising
problem in the way I'm getting the strings out.
Appreciate the very fast response!
Best, Mike
On Tue, Aug 31, 2021 at 8:14 PM Even Rouault <even.rouault at spatialys.com>
wrote:
> Michael,
> apart your code not using the same GDAL version as the one of gdalinfo
> (but I can't recall versions having such issues), or a flow in your code, I
> don't see why you'd this.
> Even
> Le 31/08/2021 à 12:07, Michael Sumner a écrit :
> Hello, I'm having trouble getting subdataset names programatically from
> the WMTS/OGC Web Map Tile Service
> Using
> /vsicurl/
> https://gibs.earthdata.nasa.gov/wmts/epsg3031/best/1.0.0/WMTSCapabilities.xml
> I see many well named SDS sources from gdalinfo, i.e. listed below.
> But when I try to obtain these programatically I only get repeated values
> : literally
> "WMTS:/vsicurl/
> https://gibs.earthdata.nasa.gov/wmts/epsg3031/best/1.0.0/WMTSCapabilities.xml,layer
> I'm using (effectively)
> char **SDS = poDataset->GetMetadata("SUBDATASETS");
> and that gives me the same value for every SDS, i.e. no layer name.
> Is there something extra that needs to be done especially for WMTS? I
> can't figure it out from the sources.
> Thanks for any help!
> Best, Mike
> gdalinfo /vsicurl/
> Driver: WMTS/OGC Web Map Tile Service
> Files: /vsicurl/
> Size is 512, 512
> Origin = (0.000000000000000,0.000000000000000)
> Pixel Size = (1.000000000000000,1.000000000000000)
> Subdatasets:
> SUBDATASET_1_NAME=WMTS:/vsicurl/
> https://gibs.earthdata.nasa.gov/wmts/epsg3031/best/1.0.0/WMTSCapabilities.xml,layer=AMSRE_Sea_Ice_Concentration_12km
> SUBDATASET_1_DESC=Layer Sea Ice Concentration (12 km, AMSR-E, Aqua)
> SUBDATASET_2_NAME=WMTS:/vsicurl/
> https://gibs.earthdata.nasa.gov/wmts/epsg3031/best/1.0.0/WMTSCapabilities.xml,layer=AMSRE_Snow_Depth_Over_Ice
> SUBDATASET_2_DESC=Layer Snow Depth Over Ice (12 km, AMSR-E, Aqua)
> SUBDATASET_3_NAME=WMTS:/vsicurl/
> https://gibs.earthdata.nasa.gov/wmts/epsg3031/best/1.0.0/WMTSCapabilities.xml,layer=AMSRE_Sea_Ice_Concentration_25km
> S
> Michael Sumner
> Software and Database Engineer
> Australian Antarctic Division
> Hobart, Australia
> e-mail: mdsumner at gmail.com
> gdal-dev mailing listgdal-dev at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/gdal-dev
> -- http://www.spatialys.com
> My software is free, but my time generally not.
Michael Sumner
Hobart, Australia
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210831/0f27cbab/attachment-0001.html>
