[gdal-dev] PGCLIENTENCODING in ogr2ogr (and QGIS)
    Even Rouault
    even.rouault at spatialys.com
    Fri Dec  3 06:04:02 PST 2021
Instead of turning Postgres client_encoding to LATIN1 (which won't work
here because -f PostgreSQL goes through the CreateDataSource() OGR API,
which will ignore destination dataset open options provided with -doo) ,
I would rather set the shapefile encoding with -oo
ENCODING=ISO-8859-1,then the OGR shapefile reader will transcode
internally from ISO-8859-1 to UTF-8, which should make Postgres API
Le 03/12/2021 à 14:55, matteo a écrit :
> Hi Rahkonen,
> sorry for the delay. The command, built with Processing in QGIS using
> the GdalUtils utility is at the end:
> ogr2ogr -f PostgreSQL "PG:dbname='db' host=myhost port=myport
> user='myuser' password='mypassword' sslmode=disable schemas=myschema"
> shapefile.shp --config PG_USE_COPY YES -append -skipfailures -nlt
> PROMOTE_TO_MULTI -doo PRELUDE_STATEMENTS="SET client_encoding TO LATIN1"
> a small file can be found here:
> https://faunalia.eu/~matteo/shapefile.zip
> and yes. The database encoding is:
> HOW SERVER_ENCODING;
>  server_encoding
>  UTF8
> (1 row)
> while the encoding of the shapefile is ISO-8859-1
> Thanks for any hint!
> Matteo
http://www.spatialys.com
