[gdal-dev] Throwing exceptions in GDAL Error Handler
Even Rouault even.rouault at spatialys.com
Sat Dec 4 15:59:52 PST 2021
You shouldn't throw C++ exceptions, as this is a callback of the C API.
This will cause all sort of issues, most of the time memory leaks, etc.
Le 05/12/2021 à 00:49, Simon Eves a écrit :
> We have a custom Error Handler callback and for a while now it was
> configured to throw an exception if the class was Failure or higher.
> Unfortunately, we have found that this causes havoc with OpenEx()
> because the file management state is left bad (e.g. the anti-recursion
> stuff) and GDAL will believe the file is open when it isn't, and other
> such hilarity.
> We have changed this to disable and re-enable the exception throw (and
> just log the error) either side of an OpenEx() but I am concerned that
> there are perhaps other situations where throwing may cause similar
> issues.
> The docs for CPLSetErrorHandler() don't explicitly say anything about
> not throwing in the callback.
> Please advise.
> SE
> <http://www.omnisci.com/>
> Simon Eves
> Senior Graphics Engineer, Rendering Group
> 100 Montgomery St (5th Floor), San Francisco, CA 94104, USA
> Email: simon.eves at omnisci.com <mailto:simon.eves at omnisci.com> | Cell:
> +1 (415) 902-1996
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20211205/309b1c16/attachment.html>
