[gdal-dev] ogrinfo XML (AIXM)
Rahkonen Jukka (MML)
jukka.rahkonen at maanmittauslaitos.fi
Thu Dec 9 01:25:28 PST 2021
Perhaps GDAL does not follow redirections automatically:
curl http://www.aixm.aero/schema/4.5/AIXM-Snapshot.xsd
<!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN">
<html><head>
<title>301 Moved Permanently</title>
</head><body>
<h1>Moved Permanently</h1>
<p>The document has moved <a href=https://www.aixm.aero/schema/4.5/AIXM-Snapshot.xsd>here</a>.</p>
</body></html>
Did you already edit your GML by changing http into https?
-Jukka Rahkonen-
Lähettäjä: paul.malm at lfv.se <paul.malm at lfv.se>
Lähetetty: torstai 9. joulukuuta 2021 11.19
Vastaanottaja: Rahkonen Jukka (MML) <jukka.rahkonen at maanmittauslaitos.fi>; even.rouault at spatialys.com; gdal-dev at lists.osgeo.org
Aihe: SV: [gdal-dev] ogrinfo XML (AIXM)
I turnd off the proxy and added -debug on.
This is the result:
ogrinfo GMLAS:c:\Temp\data\mydata.GML --debug on
GDAL: Auto register C:\Program Files\Gdal_321\bin\gdal\plugins\gdal_BAG.dll using GDALRegister_BAG.
GDAL: Auto register C:\Program Files\Gdal_321\bin\gdal\plugins\gdal_ECW_JP2ECW.dll using GDALRegister_ECW_JP2ECW.
GDAL: Auto register C:\Program Files\Gdal_321\bin\gdal\plugins\gdal_FITS.dll using GDALRegister_FITS.
GDAL: Auto register C:\Program Files\Gdal_321\bin\gdal\plugins\gdal_GMT.dll using GDALRegister_GMT.
GDAL: Auto register C:\Program Files\Gdal_321\bin\gdal\plugins\gdal_HDF4.dll using GDALRegister_HDF4.
GDAL: Auto register C:\Program Files\Gdal_321\bin\gdal\plugins\gdal_HDF4Image.dll using GDALRegister_HDF4Image.
GDAL: Auto register C:\Program Files\Gdal_321\bin\gdal\plugins\gdal_HDF5.dll using GDALRegister_HDF5.
GDAL: Auto register C:\Program Files\Gdal_321\bin\gdal\plugins\gdal_HDF5Image.dll using GDALRegister_HDF5Image.
GDAL: Auto register C:\Program Files\Gdal_321\bin\gdal\plugins\gdal_KEA.dll using GDALRegister_KEA.
GDAL: Auto register C:\Program Files\Gdal_321\bin\gdal\plugins\gdal_MG4Lidar.dll using GDALRegister_MG4Lidar.
GDAL: Auto register C:\Program Files\Gdal_321\bin\gdal\plugins\gdal_MrSID.dll using GDALRegister_MrSID.
GDAL: Auto register C:\Program Files\Gdal_321\bin\gdal\plugins\gdal_netCDF.dll using GDALRegister_netCDF.
GDAL: Auto register C:\Program Files\Gdal_321\bin\gdal\plugins\gdal_PDF.dll using GDALRegister_PDF.
GDAL: Auto register C:\Program Files\Gdal_321\bin\gdal\plugins\ogr_AmigoCloud.dll using RegisterOGRAmigoCloud.
GDAL: Auto register C:\Program Files\Gdal_321\bin\gdal\plugins-external\ogr_FileGDB.dll using RegisterOGRFileGDB.
OGR: XMLPlatformUtils::Initialize()
GMLAS: XSD cache directory: C:\Users\anpaumal\.gdal\gmlas_xsd_cache
GMLAS: noNamespaceSchemaLocation=http://www.aixm.aero/schema/4.5/AIXM-Snapshot.xsd
GMLAS: Resolving http://www.aixm.aero/schema/4.5/AIXM-Snapshot.xsd () to /vsicurl_streaming/http://www.aixm.aero/schema/4.5/AIXM-Snapshot.xsd
VSICURL: Start download for http://www.aixm.aero/schema/4.5/AIXM-Snapshot.xsd
HTTP: libcurl/7.74.0-DEV OpenSSL/1.1.1i zlib/1.2.11
VSICURL: Stop download for http://www.aixm.aero/schema/4.5/AIXM-Snapshot.xsd
ERROR 3: Cannot resolve http://www.aixm.aero/schema/4.5/AIXM-Snapshot.xsd
OGR: XMLPlatformUtils::Terminate()
FAILURE:
Unable to open datasource `GMLAS:c:\Temp\data\mydata.GML' with the following drivers.
-> BAG
-> JP2ECW
-> FITS
-> netCDF
-> PDF
-> AmigoCloud
-> FileGDB
-> ESRIC
-> PCIDSK
-> PDS4
-> VICAR
-> JP2OpenJPEG
-> MBTiles
-> EEDA
-> OGCAPI
-> DB2ODBC
-> ESRI Shapefile
-> MapInfo File
-> UK .NTF
-> LVBAG
-> OGR_SDTS
-> S57
-> DGN
-> OGR_VRT
-> REC
-> Memory
-> BNA
-> CSV
-> NAS
-> GML
-> GPX
-> LIBKML
-> KML
-> GeoJSON
-> GeoJSONSeq
-> ESRIJSON
-> TopoJSON
-> Interlis 1
-> Interlis 2
-> OGR_GMT
-> GPKG
-> SQLite
-> ODBC
-> WAsP
-> PGeo
-> MSSQLSpatial
-> OGR_OGDI
-> PostgreSQL
-> MySQL
-> OpenFileGDB
-> XPlane
-> DXF
-> CAD
-> FlatGeobuf
-> Geoconcept
-> GeoRSS
-> GPSTrackMaker
-> VFK
-> PGDUMP
-> OSM
-> GPSBabel
-> SUA
-> OpenAir
-> OGR_PDS
-> WFS
-> OAPIF
-> HTF
-> AeronavFAA
-> Geomedia
-> EDIGEO
-> SVG
-> CouchDB
-> Cloudant
-> Idrisi
-> ARCGEN
-> SEGUKOOA
-> SEGY
-> ODS
-> XLSX
-> Elasticsearch
-> Walk
-> Carto
-> SXF
-> Selafin
-> JML
-> PLSCENES
-> CSW
-> VDV
-> GMLAS
-> MVT
-> NGW
-> MapML
-> TIGER
-> AVCBin
-> AVCE00
-> HTTP
GDAL: In GDALDestroy - unloading GDAL shared library.
Från: Rahkonen Jukka (MML) <jukka.rahkonen at maanmittauslaitos.fi<mailto:jukka.rahkonen at maanmittauslaitos.fi>>
Skickat: den 9 december 2021 10:11
Till: Malm, Paul (Operations AIM) <paul.malm at lfv.se<mailto:paul.malm at lfv.se>>; even.rouault at spatialys.com<mailto:even.rouault at spatialys.com>; gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>
Ämne: Re: [gdal-dev] ogrinfo XML (AIXM)
Klicka bara på länkar och öppna bilagor om du litar på avsändaren och vet att innehållet är säkert.
The syntax is correct but "ogrinfo GMLAS:c:\Temp\data\Mydata.GML --debug on" would print much more info. Now something fails here: ERROR 3: Cannot resolve http://www.aixm.aero/schema/4.5/AIXM-Snapshot.xsd<https://url11b.mailanyone.net/v1/?m=1mvFSU-0007Mi-5p&i=57e1b682&c=3D6NElsg50_At25FG1xTAHkKYS0u-w4J9U7GdQGCYQIMPbu33hOmsgC8nWHBs-jUM4YcB5GdDGZ2OK892mNb05ysdi24X6gdolItqMAQ_OJPsMupkt1Xq3k5E1KF-zS-4rgVOMTTQTrYT1nz_TVFM9Bs8oqcnCJIVNdAYtXL0ZHHNAh1u7XhJyIocwUnOxKrfbm0X0cD3DstF-0nBmCxHwlAIq9qJXaJjfTAgbcVYDcO8HhmmedYA4hiG0DGN3tDjcExg5iqscTbqUIhXE3b7bph9HFGdGPTu8KpLFmZBopRMGz53SkPFWN1FMZuGlXp>
The schema file seems to be moved to https, I would have a try by editing that in your GML file. If you are behind a proxy server set http_proxy and https_proxy environment variables so that GDAL can access the schemas.
-Jukka Rahkonen-
Lähettäjä: gdal-dev <gdal-dev-bounces at lists.osgeo.org<mailto:gdal-dev-bounces at lists.osgeo.org>> Puolesta paul.malm at lfv.se<mailto:paul.malm at lfv.se>
Lähetetty: torstai 9. joulukuuta 2021 10.52
Vastaanottaja: even.rouault at spatialys.com<mailto:even.rouault at spatialys.com>; gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>
Aihe: Re: [gdal-dev] ogrinfo XML (AIXM)
Is this the correct syntax:
C:\>ogrinfo GMLAS:c:\Temp\data\Mydata.GML
I get the error:
FAILURE:
Unable to open datasource `GMLAS:c:\Temp\eaddata\EADdata.GML' with the following drivers.
-> BAG
-> JP2ECW
-> FITS
-> netCDF
-> PDF
-> AmigoCloud
-> FileGDB
-> ESRIC
-> PCIDSK
-> PDS4
-> VICAR
-> JP2OpenJPEG
-> MBTiles
-> EEDA
-> OGCAPI
-> DB2ODBC
-> ESRI Shapefile
-> MapInfo File
-> UK .NTF
-> LVBAG
-> OGR_SDTS
-> S57
-> DGN
-> OGR_VRT
-> REC
-> Memory
-> BNA
-> CSV
-> NAS
-> GML
-> GPX
-> LIBKML
-> KML
-> GeoJSON
-> GeoJSONSeq
-> ESRIJSON
-> TopoJSON
-> Interlis 1
-> Interlis 2
-> OGR_GMT
-> GPKG
-> SQLite
-> ODBC
-> WAsP
-> PGeo
-> MSSQLSpatial
-> OGR_OGDI
-> PostgreSQL
-> MySQL
-> OpenFileGDB
-> XPlane
-> DXF
-> CAD
-> FlatGeobuf
-> Geoconcept
-> GeoRSS
-> GPSTrackMaker
-> VFK
-> PGDUMP
-> OSM
-> GPSBabel
-> SUA
-> OpenAir
-> OGR_PDS
-> WFS
-> OAPIF
-> HTF
-> AeronavFAA
-> Geomedia
-> EDIGEO
-> SVG
-> CouchDB
-> Cloudant
-> Idrisi
-> ARCGEN
-> SEGUKOOA
-> SEGY
-> ODS
-> XLSX
-> Elasticsearch
-> Walk
-> Carto
-> SXF
-> Selafin
-> JML
-> PLSCENES
-> CSW
-> VDV
-> GMLAS
-> MVT
-> NGW
-> MapML
-> TIGER
-> AVCBin
-> AVCE00
-> HTTP
Kind regards,
Paul
Från: gdal-dev <gdal-dev-bounces at lists.osgeo.org<mailto:gdal-dev-bounces at lists.osgeo.org>> För Even Rouault
Skickat: den 8 december 2021 14:17
Till: gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>
Paul,
the GML driver can open some formulation of AIXM, but probably not all.
You may also try the generic GMLAS driver: https://gdal.org/drivers/vector/gmlas.html<https://url11b.mailanyone.net/v1/?m=1muwp2-00020I-3x&i=57e1b682&c=uz6vvUD3oCT_jv_J5c_6KFuW0bs7EadIzr6OyxIasmJB9f0PvrKackVIBaRsFK-0stBeq1jraWibIe0x4V8n-DqK_LxdtuDwLz4StmNGea8b709nnGHKo6LHjY6UtNxFRoL3LvpEKfLl3hjdjYHY9syToDuM2pO38ed50RsrAYxQmOxUUkTk4lJsAL576_C7ixRLkb6v0gGEBz19nHYgwz5tF4VetmM5wctrqTBPzgnGA3Vrxc60mpoDN6zujvfITr8U2NsMq8ucDdCh1a-zyQsms4KWk3XQaSgMr54DgjA>
Even
Le 08/12/2021 à 14:06, paul.malm at lfv.se<mailto:paul.malm at lfv.se> a écrit :
I'm trying to read a XML (AIXM) file. But ogrinfo says it can't be read with either KML, KMZ or GML installed drivers (among other formats).
Is there anything I must do, the GML, KML, KMZ drivers are there. I'm working in Windows 10.
Kind Regards,
Paul
[1_LFV_svensk_96]
Paul Malm
Operations / AIM Flyginfo SE
Direkt 08-797 70 23 Mobil 070-860 11 15
Besöks- och postadress
LFV Flyginfo SE
Af Pontins väg 6
115 21 STOCKHOLM
Tänk på miljön innan du skriver ut detta e-postmeddelande.
gdal-dev mailing list
https://lists.osgeo.org/mailman/listinfo/gdal-dev<https://url11b.mailanyone.net/v1/?m=1muwp2-00020I-3x&i=57e1b682&c=8cQdqlhVp6efzQPPPMP2SSoz1twQoc-Brn1LHEqN6oLcHdKYGbwOMLaS1ud2-c3K2wJz_BjWpsvl_sFiClF25Mkjf26TUJ0lngn57KfU5_1pvRYlSzF-TSRVK7FmkE2-lN-FzsJrpQ_uALYChCE8uKG44TrZXaSjXrm6_g5glOMqqxyXu2se8hTXiVV0TcMyWT0PM6bRtDidilS2e5dRAkGN4FniHqO-r279Xxlxc_0BS-JA8pt3peQIVgFzxvXtOViQeKZo18om84eSdbwiswYDunnqEYA2qSjoRj7hSPISZXTR0sM0VLk1J7OS85xk>
http://www.spatialys.com<https://url11b.mailanyone.net/v1/?m=1muwp2-00020I-3x&i=57e1b682&c=YwQqpD2eaPwcv6LDZBcVDWMnjpiEULCacsUNFprErGwVLGI8CsHK3CFLDUm1C9iguPEKghMKrE1S38rRIq9iX0dMmZ8_TZG28jNN05jm0SSkJg9nYMej-gdcJAdasx1eJ5jQflEf3TPJBK-Ny18ruljafZ8yd5uCbB3JPK79JbPtzHZFMCGNPSMCCnAxtihQnz7g-LFEjGKX5k1jAJ3zg-I1V5yEWedzV9cAzxofReXeozuQNOdAjImHBEhMrH-SC5OU3ZABTJyNhCfym4wWfg>
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20211209/df1530be/attachment-0001.html>
Type: image/jpeg
Desc: image001.jpg
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20211209/df1530be/attachment-0001.jpg>
