[gdal-dev] Problems compiling GDAL in ARM + NEON + libpng
Javier Jimenez Shaw
j1 at jimenezshaw.com
Fri Dec 10 04:09:18 PST 2021
Thanks!
.___ ._ ..._ .. . ._. .___ .. __ . _. . __.. ... .... ._ .__
Entre dos pensamientos racionales
hay infinitos pensamientos irracionales.
On Fri, 10 Dec 2021 at 12:52, Even Rouault <even.rouault at spatialys.com>
wrote:
> Was fixed in
> https://github.com/OSGeo/gdal/commit/1c719a864232daf58b799fbb2da785f3f9b2d579
> Le 10/12/2021 à 12:29, Javier Jimenez Shaw a écrit :
> Hi
> I am trying to compile GDAL 3.3.2 for ARM (apple M1), and I have problems
> with the included libpng. There is a missing "arm" folder in libpng. Is
> that intentional? How can I build it?
> NEON support is detected, so libpng try to use NEON optimized functions,
> but the implementation of those is missing, so I get
> Undefined symbols for architecture arm64:
> "_png_do_expand_palette_rgb8_neon", referenced from:
> _png_do_read_transformations in pngrtran.o
> "_png_do_expand_palette_rgba8_neon", referenced from:
> "_png_init_filter_functions_neon", referenced from:
> _png_read_filter_row in pngrutil.o
> "_png_riffle_palette_neon", referenced from:
> Thanks
> gdal-dev mailing listgdal-dev at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/gdal-dev
> -- http://www.spatialys.com
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20211210/b422d13b/attachment.html>
