[gdal-dev] follow warp with translate still?
Even Rouault even.rouault at spatialys.com
Thu Dec 30 14:26:17 PST 2021
Matt,
There has been an enhancement in gdalwarp to support writing directly to
drivers, like COG, that supports only the CreateCopy mode. So you don't
need the 2 step process and can directly gdalwarp -of COG (it will more
or less do the 2 steps internally)
If you output to regular GTiff, the 2 step process might be needed to
get the best compression
Even
Le 30/12/2021 à 22:29, Matt.Wilkie at yukon.ca a écrit :
> A few years ago it was best practice to follow a gdal warp process
> with translate in order to get better compression, and even overall
> speed although extra disk write is involved. Is this still the case?
> and when using COG output driver?  e.g.
> gdalwarp infile.tif interim.tif
> gdal_translate -of cog -co compress=zstd  interim.tif final.tif
> thanks!
> *Matt Wilkie*
> Geomatics Developer & Administrator
> Environment | Technology, Innovation and Mapping
> T 867-667-8133 | _Yukon.ca <http://yukon.ca/>_
> /Hours: 08:30-16:30, Mon-Wed: Office, Thu: Remote, Fri: Away./
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20211230/6fc51f04/attachment.html>
