[gdal-dev] follow warp with translate still?
Evert Etienne (SITEMARK) evert.etienne at sitemark.com
Fri Dec 31 00:04:40 PST 2021
> If you output to regular GTiff, the 2 step process might be needed to get the best compression
Are there some guidelines to when this is needed since you say 'might'?
Would it be possible to explain why this is the case?
Thanks
On Dec 30, 2021 23:26, Even Rouault <even.rouault at spatialys.com> wrote:
Matt,
There has been an enhancement in gdalwarp to support writing directly to drivers, like COG, that supports only the CreateCopy mode. So you don't need the 2 step process and can directly gdalwarp -of COG (it will more or less do the 2 steps internally)
Even
Le 30/12/2021 à 22:29, Matt.Wilkie at yukon.ca<mailto:Matt.Wilkie at yukon.ca> a écrit :
A few years ago it was best practice to follow a gdal warp process with translate in order to get better compression, and even overall speed although extra disk write is involved. Is this still the case? and when using COG output driver?  e.g.
gdalwarp infile.tif interim.tif
gdal_translate -of cog -co compress=zstd  interim.tif final.tif
thanks!
Matt Wilkie
Geomatics Developer & Administrator
Environment | Technology, Innovation and Mapping
T 867-667-8133 | Yukon.ca<https://eur03.safelinks.protection.outlook.com/?url=http%3A%2F%2Fyukon.ca%2F&data=04%7C01%7Cevert.etienne%40sitemark.com%7C956448b3d0fb4d64e85e08d9cbe36bbd%7Cfc89adff07ac47008853b7b7e906068e%7C0%7C0%7C637764999902500335%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000&sdata=RW%2FH6JNyDipGaTjWVJixD38pCPT3PlqrkmZgXQQM%2B80%3D&reserved=0>
Hours: 08:30-16:30, Mon-Wed: Office, Thu: Remote, Fri: Away.
gdal-dev mailing list
gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/gdal-dev<https://eur03.safelinks.protection.outlook.com/?url=https%3A%2F%2Flists.osgeo.org%2Fmailman%2Flistinfo%2Fgdal-dev&data=04%7C01%7Cevert.etienne%40sitemark.com%7C956448b3d0fb4d64e85e08d9cbe36bbd%7Cfc89adff07ac47008853b7b7e906068e%7C0%7C0%7C637764999902500335%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000&sdata=M%2F%2BmehTP3cdAaThPcV0bk9ChffUupqTzcsaxyJw8jho%3D&reserved=0>
http://www.spatialys.com<https://eur03.safelinks.protection.outlook.com/?url=http%3A%2F%2Fwww.spatialys.com%2F&data=04%7C01%7Cevert.etienne%40sitemark.com%7C956448b3d0fb4d64e85e08d9cbe36bbd%7Cfc89adff07ac47008853b7b7e906068e%7C0%7C0%7C637764999902500335%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000&sdata=laNHz%2FOiaBi5f62f1cxan%2FF3KcSMJvHREQ0H5ggnVSg%3D&reserved=0>
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20211231/352967e7/attachment-0001.html>
