[gdal-dev] gdalbuildvrt files not recognized
Mateusz Loskot
mateusz at loskot.net
Fri Feb 5 02:52:47 PST 2021
On Thu, 4 Feb 2021 at 23:22, Simon Shak <skunkmyrddyn at gmail.com> wrote:
> However, your suggestion to check the filelist.txt file has found the error. Somehow a trailing space was before the CRLF and caused it to not recognize the file.
There also could be an issue if there are spaces in file names.
I don't know if gdalbuildvrt can handle those on all platforms.
Best regards,
Mateusz Loskot, http://mateusz.loskot.net
