[gdal-dev] gdalbuildvrt files not recognized
Jean-Roc Morreale (ml)
jrmorreale_ml at enoreth.net
Fri Feb 5 09:19:48 PST 2021
Yep, it is easier to build your process with a listing step that you'll
feed to gdalbuildvrt. For example, on our win10 env it works with
tamas' gisinternal build with cmd but not with the conda build and cmd
Le vendredi 05 février 2021 à 08:58 -0700, Richard Greenwood a écrit :
> I think that wildcard expansion has been an on and off problem with
> some of the GDAL utilities on Windows. If you Google "gdalbuildvrt
> wildcard expansion" you'll find at least three tickets, the most
> recent of which is:
> https://github.com/OSGeo/gdal/issues/1749
> I think the safest and easiest is to use a file list if you're on
> Windows.
> On Fri, Feb 5, 2021 at 3:51 AM Mateusz Loskot <mateusz at loskot.net>
> wrote:
> > On Thu, 4 Feb 2021 at 23:22, Simon Shak <skunkmyrddyn at gmail.com>
> > wrote:
> > > However, your suggestion to check the filelist.txt file has found
> > the error. Somehow a trailing space was before the CRLF and caused
> > it to not recognize the file.
> > There also could be an issue if there are spaces in file names.
> > I don't know if gdalbuildvrt can handle those on all platforms.
> > Best regards,
> > Mateusz Loskot, http://mateusz.loskot.net
> > gdal-dev mailing list
> > gdal-dev at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/gdal-dev
