[gdal-dev] Geometry validation
    Илья Нецветаев
    notequal90 at gmail.com
    Mon Feb  8 23:02:25 PST 2021
Hello.
I have to downgrade my application from gdal 3.1.2 to 2.1.2 built on
libGeos 3.5.1. For some reason.
So I have to work around the absence of some methods introduced only in
later releases.
The first thing i met was MakeValid and IsValid. In my application it is
used for Polygons.
There is two aspects:
1. What does exactly "valid geometry" mean? What does IsValid check?
  As it is written in docs: Returns true if geometry has no points". I'm
not sure, that I understand it correctly.
2. Is there a proper way to replace MakeValid with something in order to
keep my app functional?
Thanks
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210209/c404aa91/attachment-0001.html>
