[gdal-dev] Converting KML data with styles to GeoJSON output
MRRAJESH
rajeshreddy82 at gmail.com
Mon Feb 8 23:05:41 PST 2021
Hey,
I am trying to convert a kml-file with styles to a GeoJSON. Observed that
only data is converted but styles information is missing. How to get the
Geojson data along with styles?
I have tried with org2ogr. Below is the KML file -
<?xml version="1.0" encoding="UTF-8"?><kml
xmlns="http://www.opengis.net/kml/2.2"><Document><Placemark><name>Building
41</name><styleUrl>#transBluePoly</styleUrl><Polygon><extrude>1</extrude><altitudeMode>relativeToGround</altitudeMode><outerBoundaryIs><LinearRing><coordinates>
-122.0857412771483,37.42227033155257,17-122.0858169768481,37.42231408832346,17-122.085852582875,37.42230337469744,17-122.0858799945639,37.42225686138789,17-122.0858860101409,37.4222311076138,17-122.0858069157288,37.42220250173855,17-122.0858379542653,37.42214027058678,17-122.0856732640519,37.42208690214408,17-122.0856022926407,37.42214885429042,17-122.0855902778436,37.422128290487,17-122.0855841672237,37.42208171967246,17-122.0854852065741,37.42210455874995,17-122.0855067264352,37.42214267949824,17-122.0854430712915,37.42212783846172,17-122.0850990714904,37.42251282407603,17-122.0856769818632,37.42281815323651,17-122.0860162273783,37.42244918858722,17-122.0857260327004,37.42229239604253,17-122.0857412771483,37.42227033155257,17</coordinates></LinearRing></outerBoundaryIs></Polygon></Placemark></Document></kml>
Regards,
Rajesh
Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
