[gdal-dev] Compiling GDAL with HDF4 support
Hernán De Angelis variablestarlight at gmail.com
Tue Feb 9 01:53:54 PST 2021
On 2021-02-09 10:49, Andrew C Aitchison wrote:
> On Tue, 9 Feb 2021, Hernán De Angelis wrote:
>> On 2021-02-08 20:22, Markus Metz wrote:
>>> Is /usr/local/lib64 known to your system as a path to libraries?
>>> Check the env var LD_LIBRARY_PATH or add "/usr/local/lib64" to some
>>> file in /etc/ld.so.conf.d/ followed by "ldconfig" as root.
>>> You can also set the var LDFLAGS for configure if you have libraries
>>> in a nonstandard directory, such as
>>> LDFLAGS="/usr/local/lib64" ./configure ...
>> Thank you for your suggestion, Markus, but /usr/local/Lib64 is in the
>> library path.
> What platform are you on ? On most unix systems
>     /usr/local/Lib64
> is not the same as
>     /usr/local/lib64
Thanks, I am aware of that ;-)
It was a typo in the message.
