[gdal-dev] Compiling GDAL with HDF4 support
Hernán De Angelis
variablestarlight at gmail.com
Tue Feb 9 23:24:28 PST 2021
On 2021-02-09 19:34, Markus Metz wrote:
> On Tue, Feb 9, 2021 at 10:54 AM Hernán De Angelis
> <variablestarlight at gmail.com <mailto:variablestarlight at gmail.com>> wrote:
> > On 2021-02-09 10:49, Andrew C Aitchison wrote:
> > > On Tue, 9 Feb 2021, Hernán De Angelis wrote:
> > >> On 2021-02-08 20:22, Markus Metz wrote:
> > >>> Is /usr/local/lib64 known to your system as a path to libraries?
> > >>> Check the env var LD_LIBRARY_PATH or add "/usr/local/lib64" to some
> > >>> file in /etc/ld.so.conf.d/ followed by "ldconfig" as root.
> > >>> You can also set the var LDFLAGS for configure if you have libraries
> > >>> in a nonstandard directory, such as
> > >>> LDFLAGS="/usr/local/lib64" ./configure ...
> > >> Thank you for your suggestion, Markus, but /usr/local/Lib64 is in the
> > >> library path.
> Details about the reason for the failure should be at the end of
> config.log
> My wild guess is that a library needed by HDF4 is not linked in.
Not wild by any measure, Markus, but rather spot on! There is indeed a
problem with xdr, one of those libraries (thanks Joe from hdfgroup for
tracking this down). I do not have time now to investigate this further,
unfortunately.
Best
Hernán
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210210/42e802ee/attachment.html>
