[gdal-dev] mosaicking files with partial overlap and binary mask
Patrick Young patrick.mckendree.young at gmail.com
Thu Feb 11 09:37:12 PST 2021
Not sure what the expected behavior is with gdalwarp and the underlying
mask preservation.  It is kind of a tricky problem to solve in general;
should the mask be resampled with the same kernel as used in the warp? Or
should it always be NN?  If the functionality is missing, this is a good
opportunity to get your employer funding gdal development.
A quick hack would be like you mention; you can extract the
datamask (gdal_translate -b mask ... i think) and then warp that
separately, and recombine.
P
On Thu, Feb 11, 2021 at 7:57 AM Daniele Romagnoli <
daniele.romagnoli at geo-solutions.it> wrote:
> Hi Jukka,
> sorry but I can't share the data. Is owned by a customer :(
> Long story short:
> I have several raster tiles (with size around 5000x5000) and a shapefile
> containing edges defining valid area of each tile.
> I have used gdalrasterize to extract the needed crop for each tile to
> setup a binary mask.
> Then, I have combined the binary mask with the original tile and rewritten
> as a new TIFF file with internal masks.
> Then, I'm composing all the TIFF files to a VRT.
> When rewriting that VRT to a mosaic TIFF, everything looks good. I see the
> binary mask is used to properly compose/overlap/mask the pieces of the
> mosaic and the output contains the mask too. This is an example of gdalinfo
> on one of the mosaicked tiff:
> Driver: GTiff/GeoTIFF
> Files: out.tif
> Size is 45842, 42506
> Coordinate System is:
> [... OMITTED... ]
> Metadata:
>   AREA_OR_POINT=Area
> Image Structure Metadata:
>   COMPRESSION=YCbCr JPEG
>   INTERLEAVE=PIXEL
>   JPEGTABLESMODE=1
>   JPEG_QUALITY=75
>   SOURCE_COLOR_SPACE=YCbCr
> Corner Coordinates:
>   [... OMITTED... ]
> Band 1 Block=256x256 Type=Byte, ColorInterp=Red
>   Mask Flags: PER_DATASET
> Band 2 Block=256x256 Type=Byte, ColorInterp=Green
> Band 3 Block=256x256 Type=Byte, ColorInterp=Blue
> So, as you can see the masks are added to the mosaicked dataset.
> However, when running
> gdalwarp -t_srs EPSG:NEWCODE out.tif warped.tif
> the binary mask is lost from the output file.
> I have also tried using -dstalpha but it complains that "Destination
> dataset has 3 bands, but at least 4 are needed" which makes sense.
> So I was just wondering if there is anything I should be aware of when
> warping a masked TIFF.
> I would probably try to transform the binary mask to an alpha band, do the
> warp and then convert back the alpha to a binary mask....
> Thanks for any feedback in advance.
> Regards,
> Daniele
> On Thu, Feb 11, 2021 at 3:27 PM jratike80 <
> jukka.rahkonen at maanmittauslaitos.fi> wrote:
>> Hi Daniele,
>> Test data, please.
>> -Jukka Rahkonen-
>> Daniele Romagnoli-3 wrote
>> > Thanks for the feedback, Patrick.
>> > I have downloaded the latest build from GisInternals and it worked as
>> > expected.
>> > I have another question.
>> > It looks like warping an input file containing a binary mask isn't
>> > preserving the binary mask on the output.
>> > Should I specify any flag for that?
>> > Thanks for the help.
>> > Regards,
>> > Daniele
>> > _______________________________________________
>> > gdal-dev mailing list
>> > gdal-dev at .osgeo
>> > https://lists.osgeo.org/mailman/listinfo/gdal-dev
>> Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
>> gdal-dev at lists.osgeo.org
> Regards,
> Daniele Romagnoli
> GeoServer Professional Services from the experts! Visit
> http://goo.gl/it488V for more information.
> Ing. Daniele Romagnoli
> Senior Software Engineer
> GeoSolutions S.A.S.
> Via di Montramito 3/A
> 55054  Massarosa (LU)
> Italy
> phone: +39 0584 962313
> fax:      +39 0584 1660272
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
> 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
> precisa che ogni circostanza inerente alla presente email (il suo
> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
> This email is intended only for the person or entity to which it is
> addressed and may contain information that is privileged, confidential or
> otherwise protected from disclosure. We remind that - as provided by
> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
> e-mail or the information herein by anyone other than the intended
> recipient is prohibited. If you have received this email by mistake, please
> notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210211/18a506f8/attachment.html>
