[gdal-dev] WMTS services error
Travis Kirstine traviskirstine at gmail.com
Fri Feb 12 10:43:11 PST 2021
Jukka,
I think the main issue is that the gdal_translate command throws an error
when generating the WMTS XML config file, so there is nothing to edit.
gdal_translate "WMTS:
http://www.ign.es/wmts/pnoa-ma?request=GetCapabilities&service=WMTS,layer=OI.OrthoimageCoverage,tilematrixset=EPSG:4326"
wmts_bm.xml -of WMTS
ERROR 1: Invalid dataset dimensions : -135056383 x -167901439
On Fri, 12 Feb 2021 at 10:32, jratike80 <jukka.rahkonen at maanmittauslaitos.fi>
wrote:
> Hi,
> By reading the documentation https://gdal.org/drivers/raster/wmts.html it
> could be possible to edit the automatically created XML service definition
> file or write it by hand from a scratch.
> -Jukka Rahkonen-
> Travis Kirstine wrote
> > Elena
> > This appears to be a bug in wmts driver in gdal, I would suggest filing a
> > issue
> > The below is from the OGC Two Dimensional Tile Matrix Set specs, section
> > d2
> > http://docs.opengeospatial.org/is/17-083r2/17-083r2.html
> > "NOTE4: Some implementers prefer to define this TileMatrixSet using the
> > CRS
> > http://www.opengis.net/def/crs/EPSG/0/4326. The definition is the same
> > except that CRS coordinates are expressed in latitude, longitude order,
> > affecting the TopLeftCorner and the BBox encoding only".
> > On Fri, 12 Feb 2021 at 08:05, Elena Ruiz <
> > eruiz@
> > > wrote:
> >> Hello, my goal is to obtain images of both WMS and WMTS web services
> >> using
> >> GDAL, with the CRS that each service provides, in the case of the
> >> example,
> >> how can I do then to obtain images in EPSG: 4326 or any other CRS that
> >> have
> >> changed axes? Should a parameter be added to the gdal_translate call?
> >> What
> >> would be the correct way to obtain this type of images using gdal
> >> applications like gadlinfo and gdaltranslate?
> >> I have found very little information about this on the web, many thanks
> >> and best regards
> >> *Elena Ruiz*
> >> Sofware Development & Technical Support
> >> Tel.: +34 952 43 97 71
> > eruiz@
> >> *www.aplitop.com <http://www.aplitop.com>*
> >> <http://www.aplitop.com/Product/es/6/5/tcptunnel>
> >> <http://www.aplitop.com/New/es/281/mdt-75-a-la-venta>
> >> *De:* Travis Kirstine <
> > traviskirstine@
> >> *Enviado el:* jueves, 11 de febrero de 2021 20:20
> >> *Para:* Elena Ruiz <
> > eruiz@
> >> *CC:*
> > gdal-dev at .osgeo
> >> *Asunto:* Re: [gdal-dev] WMTS services error
> >> Elena,
> >> I'm not exactly sure what is causing the issue but if you look at the
> >> capabilities of the 4326 tilematrixset compared to the InspireCRS84Quad
> >> the
> >> topleftcorner coordinates are reversed.  My guess gdal is expecting a X
> Y
> >> order.
> > <TileMatrixSet>
> > <ows:Identifier>
> > InspireCRS84Quad
> > </ows:Identifier>
> > <ows:SupportedCRS>
> > http://www.opengis.net/def/crs/OGC/1.3/CRS84
> > </ows:SupportedCRS>
> > <TileMatrix>
> > <ows:Identifier>
> > 0
> > </ows:Identifier>
> > <ScaleDenominator>
> > 2.79541132014358E8
> > </ScaleDenominator>
> > <TopLeftCorner>
> > -180.0 90.0
> > </TopLeftCorner>
> > <TileWidth>
> > 256
> > </TileWidth>
> > <TileHeight>
> > 256
> > </TileHeight>
> > <MatrixWidth>
> > 2
> > </MatrixWidth>
> > <MatrixHeight>
> > 1
> > </MatrixHeight>
> > </TileMatrix>
> > <TileMatrixSet>
> > <ows:Identifier>
> > EPSG:4326
> > </ows:Identifier>
> > <ows:SupportedCRS>
> > EPSG:4326
> > </ows:SupportedCRS>
> > <TileMatrix>
> > <ows:Identifier>
> > EPSG:4326:0
> > </ows:Identifier>
> > <ScaleDenominator>
> > 2.795411320143589E8
> > </ScaleDenominator>
> > <TopLeftCorner>
> > 90.0 -180.0
> > </TopLeftCorner>
> > <TileWidth>
> > 256
> > </TileWidth>
> > <TileHeight>
> > 256
> > </TileHeight>
> > <MatrixWidth>
> > 2
> > </MatrixWidth>
> > <MatrixHeight>
> > 1
> > </MatrixHeight>
> > </TileMatrix>
> >> On Thu, 11 Feb 2021 at 11:51, Elena Ruiz <
> > eruiz@
> > > wrote:
> >> Hello, I´m trying call web services (WMTS and WMS) using GDAL 3.0.2, but
> >> I
> >> have a problem with this example:
> >> d://wmts_bm.xml -of WMTS
> http://www.ign.es/wmts/pnoa-ma?request=GetCapabilities&service=WMTS,layer=OI.OrthoimageCoverage,tilematrixset=EPSG:25830
> >> Input file size is 20616192, 26817505
> >> In this server http://www.ign.es/wmts/pnoa-ma have available the next
> SRS
> >> SUBDATASET_1_NAME=WMTS:
> http://www.ign.es/wmts/pnoa-ma?request=GetCapabilities&service=WMTS,layer=OI.OrthoimageCoverage,tilematrixset=InspireCRS84Quad
> >> SUBDATASET_2_NAME=WMTS:
> >> SUBDATASET_3_NAME=WMTS:
> http://www.ign.es/wmts/pnoa-ma?request=GetCapabilities&service=WMTS,layer=OI.OrthoimageCoverage,tilematrixset=EPSG:4258
> >> SUBDATASET_4_NAME=WMTS:
> >> SUBDATASET_5_NAME=WMTS:
> http://www.ign.es/wmts/pnoa-ma?request=GetCapabilities&service=WMTS,layer=OI.OrthoimageCoverage,tilematrixset=GoogleMapsCompatible
> >> But when I want Know the information or download a image in certain
> >> coordinates  with EPSG:4326, it returns an error “ERROR 1: Invalid
> >> dataset
> >> dimensions : -135056383 x -167901439”, with EPSG:25830 works fine. I
> >> don`t
> >> understand this error, someone could help me?
> >> Thank you and regards
> >> *Elena Ruiz *
> >> Tel. +34 952 43 97 71
> > eruiz@
> >> Sumatra, 9 - 29190 Málaga (Spain)
> >> <https://www.facebook.com/AplitopSL/>
> >> <https://twitter.com/aplitop>
> >> <https://www.linkedin.com/company/aplitop>
> >> <https://www.youtube.com/user/aplitop>
> >> In accordance with the provisions of the European Regulation of Data
> >> Protection 2016/679 (Reglamento Europeo de Protección de Datos
> 2016/679),
> >> we inform you that the data and the information you provide us through
> >> this
> >> medium will be used by APLITOP, S.L., with C.I.F. B-92543396 and with
> >> address at C / Sumatra, 9, Malaga, 29190, in order to answer your
> >> questions
> >> and inform you about our products. The data provided will be kept as
> long
> >> as it does not request its cessation and will not be transferred to
> third
> >> parties except in cases where there is a legal obligation. You have the
> >> right to access your personal data, correct inaccurate data or request
> >> its
> >> deletion when the data is no longer necessary for the purposes that were
> >> collected, as well as any rights recognized in the RGPD 2016/679
> >> _______________________________________________
> >> gdal-dev mailing list
> > gdal-dev at .osgeo
> >> https://lists.osgeo.org/mailman/listinfo/gdal-dev
> > gdal-dev at .osgeo
> > image002.jpg (984 bytes)
> http://osgeo-org.1560.x6.nabble.com/attachment/5457213/0/image002.jpg>
> > image004.jpg (980 bytes)
> http://osgeo-org.1560.x6.nabble.com/attachment/5457213/1/image004.jpg>
> > image006.jpg (1008 bytes)
> http://osgeo-org.1560.x6.nabble.com/attachment/5457213/2/image006.jpg>
> > image008.png (918 bytes)
> http://osgeo-org.1560.x6.nabble.com/attachment/5457213/3/image008.png>
> Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210212/400c8131/attachment-0001.html>
