[gdal-dev] OGR Polygon Intersection
Kai Mühlbauer kai.muehlbauer at uni-bonn.de
Sat Feb 27 09:02:23 PST 2021
this might be a silly problem or no problem at all, but I currently
can't wrap my head around it.
I'm using python bindings of GDAL OGR with GEOS support for layer
intersection since several years now. Now suddenly my testsuit which
checks intersection of two boxes breaks since the intersecting box
starts now with a different starting point (all four points of the box
fit with the earlier tests).
The change took place between versions GDAL 3.2.0 -> 3.2.1, GEOS 3.8.1
-> 3.9.1 and PROJ 7.1.1 -> 7.2.0. I've tried to find anything what might
have changed in the release notes of GDAL and GEOS, but couldn't.
So if anyone has a clue what's going on or what has changed and can
point me to the relevant resources, I would greatly appreciate it.
Below you find the geometries I uses as JSON strings and the differing
intersection.
src
'{ "type": "Polygon", "coordinates": [ [ [ 1.0, 1.0, 0.0 ], [ 1.0, 2.0,
0.0 ], [ 2.0, 2.0, 0.0 ], [ 2.0, 1.0, 0.0 ], [ 1.0, 1.0, 0.0 ] ] ] }'
trg
'{ "type": "Polygon", "coordinates": [ [ [ 0.5, 0.5, 0.0 ], [ 0.5, 1.5,
0.0 ], [ 1.5, 1.5, 0.0 ], [ 1.5, 0.5, 0.0 ], [ 0.5, 0.5, 0.0 ] ] ] }'
trg.Intersection(src) (GDAL 3.2.0, GEOS 3.8.1, PROJ 7.1.1)
'{ "type": "Polygon", "coordinates": [ [ [ 1.0, 1.5, 0.0 ], [ 1.5, 1.5,
0.0 ], [ 1.5, 1.0, 0.0 ], [ 1.0, 1.0, 0.0 ], [ 1.0, 1.5, 0.0 ] ] ] }'
trg.Intersection(src) (GDAL 3.2.1, GEOS 3.9.1, PROJ 7.2.0)
'{ "type": "Polygon", "coordinates": [ [ [ 1.5, 1.5, 0.0 ], [ 1.5, 1.0,
0.0 ], [ 1.0, 1.0, 0.0 ], [ 1.0, 1.5, 0.0 ], [ 1.5, 1.5, 0.0 ] ] ] }'
Thanks in advance!
Cheers,
Kai
