[gdal-dev] error building gdal docker image for v2.4.4
Even Rouault
even.rouault at spatialys.com
Wed Jan 6 08:28:58 PST 2021
> Is this expected behavior? Perhaps the Dockerfile in the gdal repository is
> not backwards compatible as far back as version 2.4.4 of gdal and version
> 4.8.0 of proj?
Yes this is expected. The Dockerfile, as it, is only compatible of GDAL >= 3
and PROJ >= 6. You could tweak it to make it work with older versions. The
issue is all the renaming of libproj to libinternalproj. If you remove that,
that should hopefully work
http://www.spatialys.com
