[gdal-dev] List all the (possible) errors of a single transaction
matteo
matteo.ghetta at gmail.com
Thu Jan 7 05:08:25 PST 2021
Hi Jukka,
> One workaround is to use -skipfailures and compare afterwards which IDs in
> the source data are not present in the target table. Skipfailures is forcing
> the transaction size into one row and it may be deadly slow if the output is
> GeoPackage because initializing/committing a transaction in SQLite is slow.
> With PostGIS as an outlut it is not as slow. A dry run into some some fast,
> not transactual format like GeoJSON could be used as some sort of test but
> that does not test the database constraints.
> If you know your database and the contraints that you have you should be
> able to make quite nice tests by running SQL against the source data. But
> having a typeless SQLite as source can make it harder to write the SQL
> tests. That may even be a reason for your problems (field reserved for
> integers contains text etc.).
> I wonder why even the database engines would go on after finding the first
> error in the transaction. The whole transaction must be rollbacked in any
> case so why not to quit sooner rather than later?
thanks for the input. It seems that -skipfailures is the parameter that
I can use to do what I have to.
My idea is to use a "staging" database on PG where I can run the single
transaction with -skipfailures and then, if I don't have any errors, I
will run a similar job with the same input data but on a "production"
database.
Maybe not the cleanest solution but still a good one to catch all the
errors of all the tables
Matteo
