[gdal-dev] Considering drivers removal ?
Jan Heckman jan.heckman at gmail.com
Sun Jan 10 15:50:18 PST 2021
A bit of googling sometimes gives an indication. I was a little confused
about SVG, not using it myself but getting quite a few references.
E.g. this one in stackexchange, with a mention how often it was looked up:
https://gis.stackexchange.com/questions/11476/importing-svg-into-gis
Just an idea. Obviously, it is not easy to decide exactly what to do with
this sort of information.
Jan
On Mon, Jan 11, 2021 at 12:02 AM Even Rouault <even.rouault at spatialys.com>
wrote:
> Hi,
> It's not spring yet, but I'm in a mood lately of axing useless things, and
> we
> probably have tons of candidate for that in GDAL, especially in drivers.
> I was going to just axe the DB2 driver
> (https://github.com/OSGeo/gdal/pull/3366) but the issue is more general.
> Any idea how we can know what is used and what isn't ? A "call-home"
> functionality where we would track driver usage would only be acceptable
> if
> people enable it and have network connectivity, so we won't probably get
> lots
> of feedback. Having a spreadsheet with the driver list and asking people
> to
> fill it would probably also receive little feedback. So the idea I had was
> to
> do something like the following in the Open() method of a candidate for
> removal:
> GDALDataset* FooDriver::Open( .... )
>    if( !Identify(poOpenInfo) )
>       return nullptr;
>    if( !CPLTestBool(CPLGetConfigOption("GDAL_ENABLE_DRIVER_FOO", "NO") )
>        CPLError(CE_Failure, CPLE_AppDefined,
>     "Driver FOO is considered for removal in GDAL 3.5. You are invited "
>     "to convert any dataset in that format to another more common one ."
>     "If you need this driver in future GDAL versions, create a ticket at "
>     "https://github.com/OSGeo/gdal (look first for an existing one first)
> to "
>     "explain how critical it is for you (but the GDAL project may still "
>     "remove it), and to enable it now, set the GDAL_ENABLE_DRIVER_FOO "
>     "configuration option / environment variable to YES");
>        return nullptr;
> That is, when we detect a file to be handled by the driver, emit the above
> error message and do not open the dataset, unless the user defines the
> environment variable.
> Similarly in the Create()/CreateCopy() methods.
> If we ship this in 3.3, with a 3.5 milestone for removal, this would offer
> a
> feedback period of one year / 2 feature versions.
> Here's my own list of candidates for retirement (probably
> over-conservative).
> Mostly based on gut feeling. None of them are particularly bad citizens,
> but I
> have no indication that they are still used, which doesn't mean they
> aren't.
> * Raster side:
> BPG
> DB2Raster
> DOQ1
> DOQ2
> E00GRID
> Epsilon
> FujiBAS
> GS7BG
> GSAG
> IDA
> JDEM
> JPEG2000 (Jasper): JP2OpenJPEG is a better replacement
> JPEGLS
> LAN
> MFF
> MG4Lidar ?
> NDF
> NTv1
> SDTS Raster
> SGI
> XPM
> ZMap
> * Vector side:
> AERONAVFAA
> ESRI ArcObjects
> ARCGEN
> BNA
> Cloudant
> CouchDB
> DB2
> DODS
> FMEObjects Gateway
> Geomedia MDB
> GMT ASCII Vectors
> GTM
> HTF
> INGRES
> MongoDB (the old one, superseded by MongoDBv3)
> OpenAIR
> REC
> SDTS
> SUA
> SVG
> TIGER
> WALK
> Anything you'd add / remove ?
> What is not obvious is what would be the criterion for keeping a driver:
> 1,
> 10, 100 users asking for the driver to be kept ?
> If a GDAL developer contributing to the overall good of the project needs
> the
> preservation of a driver to be able to justify its continued involvement,
> I'd
> tend to think it to be enough to keep it.
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210111/37fbfbc8/attachment.html>
