[gdal-dev] COG overviews and SPARSE_OK
Javier Jimenez Shaw
j1 at jimenezshaw.com
Tue Jan 19 11:13:22 PST 2021
Hi all
I know how SPARSE_OK=TRUE option works in a GeoTIFF. My question is if it
is also applied in the Overviews of the COG.
In case it does not, an image of a river (linear structure) can be small in
the "main" resolution because there is a lot of sparse area, but then the
overviews can be really big (if not compressed).
Thank you,
Javier
.___ ._ ..._ .. . ._. .___ .. __ . _. . __.. ... .... ._ .__
Entre dos pensamientos racionales
hay infinitos pensamientos irracionales.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210119/df622bdb/attachment.html>
