[gdal-dev] Install error rgdal
shannon lewis
s_lewis23 at yahoo.com
Fri Jan 22 09:35:01 PST 2021
I'm getting this error trying to install newer version of rgdal, already have 1.5-16 install and working.
[: ~]$ gdal-config --version3.0.1[: ~]$ geos-config --version3.7.2[: ~]$ proj -VRel. 6.2.0, September 1st, 2019 > sessionInfo()R version 4.0.0 (2020-04-24)Platform: x86_64-pc-linux-gnu (64-bit)Running under: Red Hat Enterprise Linux Matrix products: defaultBLAS: /opt/R/R_4.0.0/lib64/R/lib/libRblas.soLAPACK: /opt/R/R_4.0.0/lib64/R/lib/libRlapack.so locale: [1] LC_CTYPE=en_US.UTF-8 LC_NUMERIC=C LC_TIME=en_US.UTF-8 LC_COLLATE=en_US.UTF-8 LC_MONETARY=en_US.UTF-8 LC_MESSAGES=en_US.UTF-8 LC_PAPER=en_US.UTF-8 [8] LC_NAME=C LC_ADDRESS=C LC_TELEPHONE=C LC_MEASUREMENT=en_US.UTF-8 LC_IDENTIFICATION=C attached base packages:[1] stats graphics grDevices datasets utils methods base loaded via a namespace (and not attached):[1] compiler_4.0.0 tools_4.0.0 renv_0.12.3 /opt/rh/devtoolset-8/root/usr/bin/g++ -std=gnu++11 -I"/opt/R/R_4.0.0/lib64/R/include" -DNDEBUG -I/usr/local/include -DPROJ_H_API -I'/usrfiles/shared-projects/shannon/RSTAN_TESTING/RSTAN_SHARE/renv/staging/3/sp/include' -I/usr/local/include -fpic -g -O2 -c proj6.cpp -o proj6.oIn file included from proj6.cpp:5:proj6.cpp: In function ‘SEXPREC* get_source_crs(SEXP)’:proj6.cpp:258:58: error: ‘PJ_WKT2_2019’ was not declared in this scope COPY_TO_USER_STRING(proj_as_wkt(ctx, target_crs, PJ_WKT2_2019, NULL))); ^~~~~~~~~~~~/opt/R/R_4.0.0/lib64/R/include/Rdefines.h:191:39: note: in definition of macro ‘COPY_TO_USER_STRING’ #define COPY_TO_USER_STRING(x) mkChar(x) ^proj6.cpp:258:58: note: suggested alternative: ‘PJ_WKT2_2018’ COPY_TO_USER_STRING(proj_as_wkt(ctx, target_crs, PJ_WKT2_2019, NULL))); ^~~~~~~~~~~~/opt/R/R_4.0.0/lib64/R/include/Rdefines.h:191:39: note: in definition of macro ‘COPY_TO_USER_STRING’ #define COPY_TO_USER_STRING(x) mkChar(x) ^proj6.cpp: In function ‘SEXPREC* proj_vis_order(SEXP)’:proj6.cpp:291:58: error: ‘PJ_WKT2_2019’ was not declared in this scope COPY_TO_USER_STRING(proj_as_wkt(ctx, target_crs, PJ_WKT2_2019, NULL))); ^~~~~~~~~~~~/opt/R/R_4.0.0/lib64/R/include/Rdefines.h:191:39: note: in definition of macro ‘COPY_TO_USER_STRING’ #define COPY_TO_USER_STRING(x) mkChar(x) ^proj6.cpp:291:58: note: suggested alternative: ‘PJ_WKT2_2018’ COPY_TO_USER_STRING(proj_as_wkt(ctx, target_crs, PJ_WKT2_2019, NULL))); ^~~~~~~~~~~~/opt/R/R_4.0.0/lib64/R/include/Rdefines.h:191:39: note: in definition of macro ‘COPY_TO_USER_STRING’ #define COPY_TO_USER_STRING(x) mkChar(x) ^proj6.cpp: In function ‘SEXPREC* P6_SRID_proj(SEXP, SEXP, SEXP, SEXP, SEXP, SEXP)’:proj6.cpp:990:52: error: ‘PJ_WKT2_2019’ was not declared in this scope if ((pszSRS = proj_as_wkt(ctx, source_crs, PJ_WKT2_2019, NULL)) ^~~~~~~~~~~~proj6.cpp:990:52: note: suggested alternative: ‘PJ_WKT2_2018’ if ((pszSRS = proj_as_wkt(ctx, source_crs, PJ_WKT2_2019, NULL)) ^~~~~~~~~~~~ PJ_WKT2_2018make: *** [proj6.o] Error 1ERROR: compilation failed for package ‘rgdal’* removing ‘/usrfiles/shared-projects/shannon/RSTAN_TESTING/RSTAN_SHARE/renv/staging/3/rgdal’Error: install of package 'rgdal' failedTraceback (most recent calls last):14: install.packages("rgdal")13: install(pkgs)12: renv_install(records, library)11: renv_install_staged(records, library)10: renv_install_default(records, library) 9: handler(package, renv_install_impl(record)) 8: renv_install_impl(record) 7: withCallingHandlers(renv_install_package_local(record), error = function(e) { vwritef("\tFAILED") writef(e$output) }) 6: renv_install_package_local(record) 5: renv_install_package_local_impl(package, path, library) 4: r_cmd_install(package, path, library) 3: r_exec(package, args, "install") 2: r_exec_error(package, output, label) 1: stop(error)
Sent from Yahoo Mail on Android
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210122/0856a945/attachment-0001.html>
