[gdal-dev] validate_cloud_optimized_geotiff.py returns invalid
Javier Jimenez Shaw
j1 at jimenezshaw.com
Fri Jan 29 14:44:35 PST 2021
Thanks for the tip. It works with gdal_translate. There was a mistake in my
side.
.___ ._ ..._ .. . ._. .___ .. __ . _. . __.. ... .... ._ .__
Entre dos pensamientos racionales
hay infinitos pensamientos irracionales.
On Fri, 29 Jan 2021 at 22:35, Patrick Young <
patrick.mckendree.young at gmail.com> wrote:
> Sorry gdal_translate!
> On Fri, Jan 29, 2021 at 2:34 PM Patrick Young <
>> What happens if you run it through "gdalwarp -of COG in.tif out.tif"?
>> On Fri, Jan 29, 2021 at 10:05 AM Javier Jimenez Shaw <j1 at jimenezshaw.com>
>> wrote:
>>> Hi all
>>> I am generating a COG file with GDAL 3.2.0 (compiled in my Ubunut 18.04)
>>> in C++
>>> Nothing strange, just
>>> GDALDriver* driver = GetGDALDriverManager()->GetDriverByName("COG");
>>> driver->CreateCopy(dst.c_str(), srcDataset, true, ...);
>>> where srcDataset is just another geotiff I opened in read mode.
>>> Later, I run the python script to validate, and returns this:
>>> ./gdal/swig/python/samples/validate_cloud_optimized_geotiff.py
>>> img_2962c146-95ec-4976-a33a-a83a8e659f88.tifcog.jpg.tiff
>>> img_2962c146-95ec-4976-a33a-a83a8e659f88.tifcog.jpg.tiff is NOT a valid
>>> cloud optimized GeoTIFF.
>>> The following errors were found:
>>> - The offset of the main IFD should be 226. It is 26010218 instead
>>> - The offset of the IFD for overview of index 0 is 4016, whereas it
>>> should be greater than the one of the main image, which is at byte 26010218
>>> Am I doing something wrong?
>>> Thank you
>>> gdal-dev mailing list
>>> gdal-dev at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210129/d509217e/attachment.html>
