[gdal-dev] GDAL 3.0 on Debian 10
Even Rouault even.rouault at spatialys.com
Thu Jul 1 02:01:09 PDT 2021
if you don't want to build from source, you could e.g.
- use a Docker image
- use a build from Conda
Even
Le 30/06/2021 à 20:42, Dirk Stenger a écrit :
> Hi all,
> Currently, I am trying to install GDAL 3.0 on Debian 10.
> Unfortunately, the package manager just provides GDAL 2 and the hints
> on https://gdal.org/download.html#debian do not tackle my case.
> What is the easiest way to install GDAL 3.0 on Debian 10? Are there
> binaries available that I can use? Is there a manual describing how to
> Can anyone help me with those questions?
> Kind regards,
> Dirk
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
