[gdal-dev] gdal_translate - unable to process srs definition....
Hill, David Foster
David.Hill at oregonstate.edu
Fri Jul 2 11:06:36 PDT 2021
Hi.
gdal_translate was working great for me for the past two weeks. I would do commands like:
—>fin="/nfs/depot/cce_u1/hill/dfh/op_snowmodel/wy_snowmodel/ctl_files/wo_assim/$STAMP.nc"
—>fout="/nfs/depot/cce_u1/hill/dfh/op_snowmodel/wy_snowmodel/ctl_files/wo_assim/$STAMP.tif"
—>gdal_translate -of GTiff -a_srs EPSG:32612 $fin $fout
from a bash script.
Now, it is not working. I get errors like:
—>Failed to process SRS definition: ESPG:32612
I don’t understand what happened. The version is: GDAL 1.11.4, released 2016/01/25
When I did printenv, I did not find that GDAL_DATA was set. So, I set it with this:
—>export GDAL_DATA=/usr/share/gdal
And, I now see that when I re-do printenv. But, I keep getting the same error? I have spent a lot of time looking for help online and can’t find anything other than making sure gdal_data is correctly set, which it now is.
Regards,
David F. Hill
Professor
Civil and Construction Engineering
Oregon State University
220 Owen Hall
Corvallis, OR 97331
541.737.4939
david.hill at oregonstate.edu
http://www.engr.oregonstate.edu/~dfh
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210702/36f5d480/attachment-0001.html>
Type: application/pkcs7-signature
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210702/36f5d480/attachment-0001.bin>
