[gdal-dev] Setting roles in PostGIS connection
Pekka Sarkola pekka at gispo.fi
Sun Jul 4 21:55:24 PDT 2021
Hi Even,
That's correct: I use ogr2ogr. At least I tested with "-overwrite", but I
will check how this works with "-update"
Rgs,
Pekka
Pekka Sarkola
Gispo Oy
pekka.sarkola at gispo.fi   - GSM +358 40 725 2042
www.gispo.fi – www.paikkatieto.com
pe 2. heinäk. 2021 klo 17.26 Even Rouault (even.rouault at spatialys.com)
kirjoitti:
> Pekka,
> I suspect you use "ogr2ogr -f PostgreSQL PG:....."
> If you use rather "ogr2ogr -update PG:...." you should be able to use -doo
> (not sure the SET ROLE will work properly in that context though)
> Even
> Le 02/07/2021 à 08:52, Pekka Sarkola a écrit :
> Hi!
> We have a PostGIS database with login roles and group roles (like
> "admins", "editors" and "viewers"). We have defined that only "admins" can
> create new schemas and tables (among other privileges). My problem is that
> I'd like to use ogr2ogr to bulk load some data to a PostGIS database using
> ogr2ogr with a certain login role with "admins" role.
> It seems that it is not possible to define roles in PostgreSQL connection
> parameters (my first try) or in PostgreSQL driver options.
> I tried to use PREDUDE_STATEMENTS like: "-doo "PRELUDE_STATEMENTS=SET ROLE
> admins", but got warning "Warning 1: -doo ignored when creating the output
> datasource."
> Any solutions or suggestions?
> There is also similar case in QGIS: Supporting "set role" when connecting
> to a postgres database - https://github.com/qgis/QGIS/issues/42763
> Versions: GDAL 3.0.4, released 2020/01/28, PostgreSQL 12.7, PostGIS 3.1
> Rgs,
> Pekka
> Pekka Sarkola
> Gispo Oy
> gdal-dev mailing listgdal-dev at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/gdal-dev
> -- http://www.spatialys.com
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210705/398cfb19/attachment.html>
