[gdal-dev] Fwd: gdaladdo fails on some images
Simone Dalmasso simone.dalmasso at gmail.com
Wed Jul 7 08:01:34 PDT 2021
Dear Even,
thanks for the answer although I solved it by introducing rio-cogeo and
works fine.
Best!
Il giorno mar 6 lug 2021 alle ore 08:39 Even Rouault <
even.rouault at spatialys.com> ha scritto:
> Simone,
> we'd need to access one of dataset that fails.
> Even
> Le 05/07/2021 à 09:36, Simone Dalmasso a écrit :
> Dear list,
> I'm running gdaladdo on some imagery, SPOT and Sentinel2.
> But only on one S2 works fine, on the others stops with only "Overview
> building failed".
> My command is simply "gdaladdo -r nearest path".
> I noticed that it will work if I specify to just up to 16 the OVR levels,
> but as soon as I put 32 it fails. (as said on one S2 works fine)
> GDAL version is 3.2.1, OS Focal64, the output with CPL_DEBUG ON is:
> GTiff.
> GTiff: ScanDirectories()
> GTiff: Opened 6492x4548 overview.
> GTiff: Opened 3246x2274 overview.
> GTiff: Opened 1623x1137 overview.
> GTiff: Opened 812x569 overview.
> GTiff: Opened 406x285 overview.
> GTiff: Opened 203x143 overview.
> 0GDAL: GDAL_CACHEMAX = 291 MB
> ...10...20...30...40...50...60...70...80...90...100 - done.
> Overview building failed.
> GDAL: Flushing dirty blocks:
> 0...10...20...30...40...50...60...70...80...90...100 - done.
> etc etc
> Thanks a lot for your support.
> Simone
> gdal-dev mailing listgdal-dev at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/gdal-dev
> -- http://www.spatialys.com
> My software is free, but my time generally not.
Simone
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210707/7bfdb7af/attachment.html>
