[gdal-dev] gdaladdo bigtiff err but --config BIGTIFF was used
Matt.Wilkie at yukon.ca Matt.Wilkie at yukon.ca
Thu Jul 8 08:53:19 PDT 2021
cogger v0.0.5 now supports .ovr external overviews. It will automatically set the output cog to bigtiff if required, so your use-case should now be covered.
Oh that’s great, thank you!
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210708/5632e7cd/attachment.html>
