[gdal-dev] a flag for translate stop or abort on error?
Matt.Wilkie at yukon.ca Matt.Wilkie at yukon.ca
Thu Jul 8 14:31:31 PDT 2021
Good to know, thanks.
For the rest of the set I'm going to unpack the archives first instead using /vsizip. I'm making several passes over the contents and some testing has shown that is slowing things down a lot. If I manage to find a reproducible set I'll let you know.
-Matt
Matt,
when you get the "TIFFReadEncodedTile() failed.", it is in a failure path of the geotiff driver, so the processing should stop immediately. I suspect something later in the stack (VRT driver?) doesn't, but without a reproducer to investigate what's going on exactly, hard to tell
Even
Le 08/07/2021 à 18:17, Matt.Wilkie at yukon.ca<mailto:Matt.Wilkie at yukon.ca> a écrit :
http://www.spatialys.com<https://imsva91-ctp.trendmicro.com:443/wis/clicktime/v1/query?url=http%3a%2f%2fwww.spatialys.com&umid=0763D56F-C69F-B605-A36A-1A70FA6A0A31&auth=c132af8ee7c9d1278d61a701569070a095ce962e-9f7f02676c852557b250faa4e51fdba9dce73888>
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210708/f04d840d/attachment.html>
