[gdal-dev] Computing my overviews for GeoTIFF
Javier Jimenez Shaw j1 at jimenezshaw.com
Tue Jul 13 09:24:33 PDT 2021
Sounds good.
My next question is how to write the overviews data efficiently.
I see that there is a method "GDALRasterBand * GDALRasterBand::GetOverview
( int i ) ", but for that I need to deinterlace the image (copying it), and
call it 4 times. Is there any trick I am missing while calling
GDALRasterBand::RasterIO? Maybe some black magic with the pixel and line
spaces? The images/overviews I get from the GPU are interlaced (RGBARGBA)
On the other side there is "GDALDataset::RasterIO(...)", but there is not
explicit way to set the overview level.
Thanks
.___ ._ ..._ .. . ._.  .___ .. __ . _. . __..  ... .... ._ .__
Entre dos pensamientos racionales
hay infinitos pensamientos irracionales.
On Tue, 13 Jul 2021 at 14:04, Even Rouault <even.rouault at spatialys.com>
wrote:
> Javier,
> You can use the "NONE" resampling method in BuildOverviews() or gdaladdo
> to create the overviews IFD without allocating any storage, and then you
> can open the file in update mode to set whatever values you want.
> APPEND_SUBDATASET=YES will not set the appropriate value for the
> SubFileType TIFF tag, and thus such pages won't be recognized as overviews
> Even
> Le 13/07/2021 à 13:57, Javier Jimenez Shaw a écrit :
> Hi
> I am computing the overviews of a GeoTIFF on my own (using the GPU, much
> faster), and I want to include them in the tif file (also in the ovr
> sidecar file).
> What is the best way to do it? Just creating a multipage TIFF (I guess
> with the option APPEND_SUBDATASET=YES)? Is there anything else needed
> (metadata, tiff tags, etc)?
> So far I want to do it in RGBA 8 bit images. (In the future I want to do
> it also in float32 images with nodata value and any number of bands, but no
> hurry).
> I am using GDAL 3.3.1
> Any help is welcome.
> Thanks.
> Javier.
> gdal-dev mailing listgdal-dev at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/gdal-dev
> -- http://www.spatialys.com
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210713/b6f84911/attachment.html>
