[gdal-dev] Get bounds of object before reprojection?
Craig Delancy
cdelancy at blackfangtechnologies.com
Tue Jul 13 14:21:05 PDT 2021
Using the c++ API, how would I go about getting the bounds of a raster dataset, reprojected into another projection, without actually performing the reprojection first? Is there a way to do this, or do I have to do the reprojection to get this info?
I was thinking I could get the corners and reproject them as points, but I think this could give an incorrect answer depending on the target projection.
Thank you.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210713/eb9562f5/attachment.html>
