[gdal-dev] Large GeoJSONs and aborting file opening
Mike Flannigan
mflan at mflan.com
Thu Jul 29 09:36:42 PDT 2021
Thank you.
These building outlines don't produce fields that are extremely wide
(lots of characters on a single line). But I tend to store my geoj's
with each point on a single line, to prevent excessively wide lines.
It makes a BIG difference for QGIS with the geoj's I work with.
You might try that just to see if it makes a difference for you.
So you could replace "],[" with "],\n[" (\n being a newline). The file
might get even bigger, but QGIS is much happier with the newlines than
with the wide rows.
Mike
On 7/29/21 9:26 AM, Newcomb, Doug wrote:
> https://github.com/microsoft/USBuildingFootprints
> <https://github.com/microsoft/USBuildingFootprints>
> GitHub - microsoft/USBuildingFootprints: Computer generated building
> footprints for the United States
> Introduction. Microsoft Maps is releasing country wide open building
> footprints datasets in United States. This dataset contains
> 129,591,852 computer generated building footprints derived using our
> computer vision algorithms on satellite imagery.
> github.com
> Texas is 2.38 GB , but you get a variety of other sizes
> *From:* gdal-dev <gdal-dev-bounces at lists.osgeo.org> on behalf of Mike
> Flannigan <mflan at mflan.com>
> *Sent:* Thursday, July 29, 2021 9:49 AM
> *To:* gdal-dev at lists.osgeo.org <gdal-dev at lists.osgeo.org>
> *Subject:* [EXTERNAL] Re: [gdal-dev] Large GeoJSONs and aborting file
> opening
> This email has been received from outside of DOI - Use caution before
> clicking on links, opening attachments, or responding.
> I would like to hear more about large GeoJSON files.
> How large are they?
> My GeoJSON files contain linear features only. My
> largest one is 50.2 MB with 1,230,000 newlines in it.
> Next biggest one is 12 MB with 280,000 newlines. These
> and about 140 other geojsons are open in the same project
> and I have no problems. In fact I converted from
> SHP to geojson 2 years ago because I used to have problems
> with SHP linear files.
> I use QGIS 3.16.8 on Linux Mint.
> Mike
> On 7/28/21 2:36 PM, gdal-dev-request at lists.osgeo.org wrote:
> > Date: Wed, 28 Jul 2021 12:22:12 -0700
> > From: Simon Eves<simon.eves at omnisci.com>
> > To:gdal-dev at lists.osgeo.org
> > Subject: [gdal-dev] Large GeoJSONs and aborting file opening
> > Message-ID:
> > <CAJf0KTRsaskSOsPv8tbA+iTB+TqL_ui5y4n05WGLDw_3guRs4w at mail.gmail.com>
> > Content-Type: text/plain; charset="utf-8"
> > Dear All,
> > I am aware that some improvements were made in the 2.3 timeframe with
> > regards to dealing with large GeoJSON files, although even in 3.2, it's
> > still very slow and memory hungry.
> > Our system allows for aborting imports, but this only works reliably
> once
> > it has actually got to the stage of reading features from the file. With
> > the GeoJSON, it just sits in the GDALOpenEx call for ages.
> > My question, therefore, is whether it might be practical to run the
> > GDALOpenEx in a separate thread with a future to return the resulting
> > handle, such that it could be monitored and killed if necessary?
> > Mainly I would be concerned that killing the thread might trash some
> global
> > GDAL state that might then not be recoverable, or that the open
> relies on
> > some TLS for the process thread and therefore might not work properly.
> > We're going to try it anyway, but opinions welcomed, thanks!
> > Simon
> gdal-dev mailing list
> https://gcc02.safelinks.protection.outlook.com/?url=https%3A%2F%2Flists.osgeo.org%2Fmailman%2Flistinfo%2Fgdal-dev&data=04%7C01%7Cdoug_newcomb%40fws.gov%7C4a700f32558543c33b2308d9529c3a35%7C0693b5ba4b184d7b9341f32f400a5494%7C0%7C0%7C637631653236424668%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000&sdata=86Xw3QEVbY0bqUurcBL8iLFi9IVjl0vGyErJUclKFFg%3D&reserved=0
> <https://gcc02.safelinks.protection.outlook.com/?url=https%3A%2F%2Flists.osgeo.org%2Fmailman%2Flistinfo%2Fgdal-dev&data=04%7C01%7Cdoug_newcomb%40fws.gov%7C4a700f32558543c33b2308d9529c3a35%7C0693b5ba4b184d7b9341f32f400a5494%7C0%7C0%7C637631653236424668%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000&sdata=86Xw3QEVbY0bqUurcBL8iLFi9IVjl0vGyErJUclKFFg%3D&reserved=0>
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210729/8ccd5a43/attachment.html>
