[gdal-dev] [EXTERNAL] Re: Large GeoJSONs and aborting file opening
Newcomb, Doug
doug_newcomb at fws.gov
Thu Jul 29 11:16:53 PDT 2021
I just converted them to geopackage layers and went from there.
Doug
From: gdal-dev <gdal-dev-bounces at lists.osgeo.org> on behalf of Mike Flannigan <mflan at mflan.com>
Sent: Thursday, July 29, 2021 1:28 PM
To: Simon Eves <simon.eves at omnisci.com>
Cc: gdal-dev at lists.osgeo.org <gdal-dev at lists.osgeo.org>
Subject: [EXTERNAL] Re: [gdal-dev] Large GeoJSONs and aborting file opening
This email has been received from outside of DOI - Use caution before clicking on links, opening attachments, or responding.
Yeah, there must be a way of breaking this up in Postgis or some other
method. Maybe by county or city region, if that meets your workflow
needs. I would break it up outside of QGIS, and then import the various
geoj's into QGIS.
I'm thinking these methods don't work on a geoj:
https://www.reddit.com/r/QGIS/comments/mbljrw/render_visible_layers_only/<https://gcc02.safelinks.protection.outlook.com/?url=https%3A%2F%2Fwww.reddit.com%2Fr%2FQGIS%2Fcomments%2Fmbljrw%2Frender_visible_layers_only%2F&data=04%7C01%7Cdoug_newcomb%40fws.gov%7C6ed70bff2fda471014ab08d952b9edc2%7C0693b5ba4b184d7b9341f32f400a5494%7C0%7C0%7C637631781801562533%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000&sdata=0NB3OrZA5ngYcz8b6QqRy%2Fen%2BAAIk9jc6Uu0j0Fo3CA%3D&reserved=0>
https://gis.stackexchange.com/questions/111784/displaying-only-selected-features-on-map-in-qgis<https://gcc02.safelinks.protection.outlook.com/?url=https%3A%2F%2Fgis.stackexchange.com%2Fquestions%2F111784%2Fdisplaying-only-selected-features-on-map-in-qgis&data=04%7C01%7Cdoug_newcomb%40fws.gov%7C6ed70bff2fda471014ab08d952b9edc2%7C0693b5ba4b184d7b9341f32f400a5494%7C0%7C0%7C637631781801562533%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000&sdata=CjG5lHGmA%2BK6plQuGhY2d2wZ0I97T7k2GR1SBM9i7nk%3D&reserved=0>
Mike
On 7/29/21 11:30 AM, Simon Eves wrote:
The problematic one in this case is about 30GB, with ~5.9M features, of property parcels in Florida, each with polygons with 5-10 vertices and 57 (!) other columns. Below is the first feature as printed by ogrinfo. It appears to have originated as a Shapefile, which we have also converted to regular GeoJSON (the 30GB one), and linear GeoJSONL/Seq.
The Shapefile version imports with no issues or obvious delays, with features flowing basically immediately, and the overall process taking about 7 minutes.
The regular GeoJSON version spends over 20 minutes in the GDALOpenEx call, and another 10 minutes before features flow (haven't looked yet in what), after which it takes about the same 7 minutes.
The GeoJSONL/Seq version spends about 12 minutes in GDALOpenEx and then the same 10 minutes, and then the same 7 minutes.
Note that ogrinfo has the same initial delays (20 minutes and 12 minutes) before it prints anything.
This is all with GDAL 3.2.2 on Ubuntu 20.04 on a quad i7 4.2 with 32GB and SSD.
The 7 minutes of import is not the issue, and once features are flowing, our code is able to be aborted. The issue is the 20-30 minutes where it can't because it's (seemingly) stuck in GDAL calls.
Simon
OGRFeature(fl_parcels):0
CNTYNAME (String) = ESCAMBIA
LINK (String) = 27-083S321301060003
PARCELID (String) = 083S321301060003
NPARNO (String) = 12-033-083S321301060003
DORUC (String) = 000
PAUC (String) = 1
PARUSEDESC (String) = VACANT RESIDENTIAL
SPASS_CD (String) = (null)
IMPROVVAL (Integer) = 0
LNDVAL (Integer64) = 1069
JV (Integer64) = 1069
JV_CHNG (Integer) = (null)
JV_HMSTD (Integer) = (null)
AV_SD (Integer64) = 1069
AV_NSD (Integer64) = 1069
AV_HMSTD (Integer) = (null)
JV_CLASS_U (Integer) = (null)
ONAME (String) = GRAF MABIE PARTNERSHIP
OADDR1 (String) = 5544 BAKER RD
OADDR2 (String) = (null)
OCITY (String) = MILTON
OSTATE (String) = FL
OZIPCD (String) = 32570
PHYADDR1 (String) = (null)
PHYCITY (String) = PERDIDO KEY
PHYZIP (String) = 32507
SLEGAL (String) = LT 6 BLK 3 PERDIDO BAY COUNTRY
ALTKEY (String) = 103002391
ACTYRBLT (Integer) = (null)
EFFYRBLT (Integer) = (null)
TOTLVGAREA (Integer) = (null)
NOBULDNG (Integer) = (null)
NORESUNTS (Integer) = (null)
PARSPLT (String) = (null)
LNDSQFOOT (Real) = 14610.000000000000000
CONSTCLASS (String) = (null)
SALEPRC1 (Integer64) = (null)
SALEYR1 (Integer) = (null)
SALEMO1 (Integer) = (null)
ORBOOK1 (String) = (null)
ORPAGE1 (String) = (null)
SALEPRC2 (Integer) = (null)
SALEYR2 (Integer) = (null)
SALEMO2 (Integer) = (null)
NBRHDCD (String) = (null)
PUBLICLND (String) = (null)
TAXAUTHCD (String) = MSTU
SEC (String) = 8
TWN (String) = 03S
RNG (String) = (null)
CENSUSBK (String) = 12033002604
SOURCEAGE (String) = ESCAMBIA COUNTY PROPERTY APPRAISER
SOURCEDATE (Integer64) = 1506643200
LAT_DD (Real) = 30.334948776670700
LONG_DD (Real) = -87.417015732515793
MGRS (String) = 16RDU5991555975
ACRES (Real) = 0.335475404173654
EXMPT (String) = (null)
LU_RES (String) = (null)
LUCODE (String) = 000
GCID (Integer) = 3070217
DESCRIPT (String) = VACANT RESIDENTIAL
FLAG (String) = (null)
FGDLAQDATE (Integer64) = 1509494400
AUTOID (Integer) = 3070217
Shape_Leng (Real) = 161.443473611912992
Shape_Area (Real) = 1357.620793937390090
POLYGON ((-87.4169063602653 30.3347107536787,-87.4169237108049 30.3346997733855,-87.4172722303389 30.3349846323649,-87.41724423478
23 30.3350359296124,-87.4172384512691 30.3351985804435,-87.4171183385966 30.335195856325,-87.4169790313658 30.3350555432658,-87.4167
283286418 30.3348031641612,-87.4167416558679 30.3347974225575,-87.4167635326352 30.3347875319118,-87.4167852417644 30.3347773059899,
-87.4168030952182 30.334768463082,-87.4168206972148 30.3347594525361,-87.4168382153925 30.3347501905331,-87.416855482113 30.33474067
7073,-87.4168725811955 30.3347309121558,-87.4168895964589 30.334720937691,-87.4169063602653 30.3347107536787))
On Thu, Jul 29, 2021 at 6:49 AM Mike Flannigan <mflan at mflan.com<mailto:mflan at mflan.com>> wrote:
I would like to hear more about large GeoJSON files.
How large are they?
My GeoJSON files contain linear features only. My
largest one is 50.2 MB with 1,230,000 newlines in it.
Next biggest one is 12 MB with 280,000 newlines. These
and about 140 other geojsons are open in the same project
and I have no problems. In fact I converted from
SHP to geojson 2 years ago because I used to have problems
with SHP linear files.
I use QGIS 3.16.8 on Linux Mint.
Mike
On 7/28/21 2:36 PM, gdal-dev-request at lists.osgeo.org<mailto:gdal-dev-request at lists.osgeo.org> wrote:
> Date: Wed, 28 Jul 2021 12:22:12 -0700
> From: Simon Eves<simon.eves at omnisci.com<mailto:simon.eves at omnisci.com>>
> To:gdal-dev at lists.osgeo.org<mailto:To%3Agdal-dev at lists.osgeo.org>
> Subject: [gdal-dev] Large GeoJSONs and aborting file opening
> Message-ID:
> <CAJf0KTRsaskSOsPv8tbA+iTB+TqL_ui5y4n05WGLDw_3guRs4w at mail.gmail.com<mailto:CAJf0KTRsaskSOsPv8tbA%2BiTB%2BTqL_ui5y4n05WGLDw_3guRs4w at mail.gmail.com>>
> Content-Type: text/plain; charset="utf-8"
> Dear All,
> I am aware that some improvements were made in the 2.3 timeframe with
> regards to dealing with large GeoJSON files, although even in 3.2, it's
> still very slow and memory hungry.
> Our system allows for aborting imports, but this only works reliably once
> it has actually got to the stage of reading features from the file. With
> the GeoJSON, it just sits in the GDALOpenEx call for ages.
> My question, therefore, is whether it might be practical to run the
> GDALOpenEx in a separate thread with a future to return the resulting
> handle, such that it could be monitored and killed if necessary?
> Mainly I would be concerned that killing the thread might trash some global
> GDAL state that might then not be recoverable, or that the open relies on
> some TLS for the process thread and therefore might not work properly.
> We're going to try it anyway, but opinions welcomed, thanks!
> Simon
[http://www2.omnisci.com/l/298412/2018-09-18/3sqpg/298412/61753/OmniSci_Email_Header2.png]<https://gcc02.safelinks.protection.outlook.com/?url=http%3A%2F%2Fwww.omnisci.com%2F&data=04%7C01%7Cdoug_newcomb%40fws.gov%7C6ed70bff2fda471014ab08d952b9edc2%7C0693b5ba4b184d7b9341f32f400a5494%7C0%7C0%7C637631781801572491%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000&sdata=XYs9TEZeQyJhogwTVfjzY2DY%2FDeey7Flbeorpvmh%2FGw%3D&reserved=0>
Simon Eves
Senior Graphics Engineer, Rendering Group
100 Montgomery St (5th Floor), San Francisco, CA 94104, USA
Email: simon.eves at omnisci.com<mailto:simon.eves at omnisci.com> | Cell: +1 (415) 902-1996
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210729/bce04803/attachment-0001.html>
