[gdal-dev] Making use of SPOT imagery mask files
Matt.Wilkie at yukon.ca
Thu Jul 29 15:42:56 PDT 2021
Aha! A small bit of progress:
$ gdaltransform -rpc DS_SPOT6_201308032015087_LM1_FR1_FR1_FR1_W137N65_10315\PROD_SPOT6_001\VOL_SPOT6_001_A\IMG_SPOT6_MS_001_A\DIM_SPOT6_MS_201308032015087_SEN_1.XML
Enter column line values separated by space, and press Return.
0.0 57083.0
-137.766376889524 63.1915449659547 0
9652.0 0.0
-136.420879379204 66.6213864498263 0
These are the corner coordinates of the gdalinfo report, and they match the image as ArcMap displays it.
[cid:image002.jpg at 01D78490.652687E0]
So in python we could loop through the vertices of each GML polygon coordinate pair and transform using the above method, but it seems there should or could be a more straightforward path.
-Matt
From: gdal-dev <gdal-dev-bounces at lists.osgeo.org<mailto:gdal-dev-bounces at lists.osgeo.org>> On Behalf Of Matt.Wilkie at yukon.ca<mailto:Matt.Wilkie at yukon.ca>
Sent: July 28, 2021 2:58 PM
To: gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>
Subject: [gdal-dev] Making use of SPOT imagery mask files
I'm working with SPOT 6 and 7 imagery delivered in DIMAP format. I've figured out how to extract the multispectral and pan-chromatic bands into geotiff with gdal-translate so they're easier to work with.
((cross posted to https://gis.stackexchange.com/questions/405077/making-use-of-spot-imagery-mask-files))
In each archive there are a series of mask files in gml<https://gis.stackexchange.com/questions/tagged/gml> format, which I can read with ogrinfo and Qgis. However the mask files don't have a coordinate system so I can't use them with the images.
From the ogrinfo report it appears the GML are using image row and column pixel dimensions. (The matching source image is 9652 x 57083.)
$ ogrinfo \SPOT6_sample_roi.gml maskfeature
INFO: Open of `\SPOT6_sample_roi.gml'
using driver `GML' successful.
Metadata:
NAME=Area of interest mask for product id SPOT6_MS_201308032015087_SEN_SPOT6_20160316_1601281mdxzlrvssw12_1
Layer name: MaskFeature
Geometry: Polygon
Feature Count: 1
Extent: (1.000000, 1.000000) - (9653.000000, 57084.000000)
Layer SRS WKT:
(unknown)
gml_id: String (0.0) NOT NULL
maskType: String (18.0)
OGRFeature(MaskFeature):0
gml_id (String) = REGION_OF_INTEREST-0
maskType (String) = REGION_OF_INTEREST
POLYGON ((9645.1767578125 6.41328716278076,9645.162109375 5.32240867614746,9645.03125 4.30024194717407,9644.7841796875 3.2741334438324,9644.5390625 2.39344930648804,9644.181640625 1.72693908214569,9643.7666015625 1.20388793945312,9643.4931640625 1.0,8939.99609375 1.0,1.0 4.3671669960022,1.0 28542.5,1 57084,9653 57084,9653.0 45960.265625,9645.1767578125 6.41328716278076))
The gdalinfo report for the source image<https://gist.github.com/maphew/513404f56b956ef3f1379b70d1d5d87f> also shows pixel coordinates for the coordinate system:
Corner Coordinates:
Upper Left ( 0.0, 0.0)
Lower Left ( 0.0,57083.0)
Upper Right ( 9652.0, 0.0)
Lower Right ( 9652.0,57083.0)
Center ( 4826.0,28541.5)
However it also has RPC metadata that seems to be enough to have Qgis and ArcMap/Pro display it in the right geographical location:
RPC Metadata:
HEIGHT_OFF=500.0
HEIGHT_SCALE=500.0
LAT_OFF=64.90742355
LAT_SCALE=1.71583845
...snip...
SAMP_OFF=4825
SAMP_SCALE=4826.0
Sample files at https://drive.google.com/drive/folders/119QEECJ42FKt0A9mq55rRmGsT9-5nSZq?usp=sharing<https://imsva91-ctp.trendmicro.com:443/wis/clicktime/v1/query?url=https%3a%2f%2fdrive.google.com%2fdrive%2ffolders%2f119QEECJ42FKt0A9mq55rRmGsT9%2d5nSZq%3fusp%3dsharing&umid=DDB23C05-C836-5F05-8C43-D9C4E8793F41&auth=c132af8ee7c9d1278d61a701569070a095ce962e-8392e73310668c1bcd34a5a3858e847f80e42556> (The image has been resized to 10% of it's original size.)
How might I marry the raster coordinate system info to the mask files so I can use them together?
Thanks in advance for your time and thoughts,
Matt Wilkie
A / Manager
(Geomatics Developer & Administrator)
Environment | Technology, Innovation and Mapping
T 867-667-8133 | Yukon.ca<https://imsva91-ctp.trendmicro.com:443/wis/clicktime/v1/query?url=http%3a%2f%2fyukon.ca&umid=DDB23C05-C836-5F05-8C43-D9C4E8793F41&auth=c132af8ee7c9d1278d61a701569070a095ce962e-b4a5ffa0a5f9c86e6d2b5c3020b56a517356be74>
Hours: 08:30-16:30, Mon-Wed: Office, Thu: Remote, Fri: Away.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210729/cad18054/attachment-0001.html>
Type: image/jpeg
Desc: image002.jpg
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210729/cad18054/attachment-0001.jpg>
