[gdal-dev] Downscaled geotiff with overviews
Even Rouault even.rouault at spatialys.com
Fri Jul 30 12:33:18 PDT 2021
If you initialize empty overviews ( BuildOverviews("NONE", ... ) ), then
you can read the downscaled version of the original geotiff and put that
in the target overviews. Of course you'll pay the price of
decompression/recompression. By using directly the libtiff API, you
could save that
Even
Le 30/07/2021 à 20:19, Javier Jimenez Shaw a écrit :
> Hi
> I want to make a (power-of-two) downscaled version of a geotiff with
> overviews efficiently with C++ (not from the console).
> Let's say I have a geotiff with overviews (external or internal), and
> I want a copy of it, but at 50% of the size. That is just removing the
> "base" of the pyramid, but keeping all the other levels. Then voilà,
> there you have the geotiff 50% smaller, with the overviews already
> there, almost without any computation. The same for 25% (and any power
> of 2).
> However I do not figure out how to do it efficiently in C++. If I
> understand correctly, CreateCopy is producing an image with the same
> size. So to downscale I have to create a new image, read downscaled
> (that will use the overviews) and write. But later, I have to recreate
> the overviews on the new image... that are already in the original image.
> Is there any way to make it efficiently? (as we have the data there)
> Thanks.
> .___ ._ ..._ .. . ._. .___ .. __ . _. . __..  ... .... ._ .__
> Entre dos pensamientos racionales
> hay infinitos pensamientos irracionales.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210730/b828a7e1/attachment.html>
