[gdal-dev] VRT layer definition question
jratike80 jukka.rahkonen at maanmittauslaitos.fi
Tue Jun 1 02:46:57 PDT 2021
Ogrinfo finds numbers from the .csv file with a little help:
ogrinfo csv.csv csv -al -oo autodetect_type=yes
Ogrinfo finds numbers from the .csv file automatically, probably because the
fields are mapped into real in the vrt file:
ogrinfo csv.vrt -al -so
But ogrmerge.py does have a problem:
ogrmerge f csv -o merged.csv csv.vrt
Warning 1: The 'lon' and/or 'lat' fields of the source layer are not
declared as numeric fields, so the spatial filter cannot be turned into an
attribute filter on them
Ogrmerge runs when I add a mapping file .csvt
csv.csvt
Real,Real,String
It seems to me that your vrt file is OK but there is some issue in the
ogrmerge.py script that does not get the data type of the field correctly
from vrt. Write the csvt file and you should be fine.
-Jukka Rahkonen-
Al Piszcz wrote
> Jukka:
> Thank you, interesting, lat,lon interpreted as string by gdalinfo.
> ==== Request 1
> ogrinfo file1.csv -al -so
> INFO: Open of `file1.csv'
>       using driver `CSV' successful.
> Layer name: file1
> Geometry: None
> Feature Count: 1000
> Layer SRS WKT:
> (unknown)
> lon: String (0.0)
> lat: String (0.0)
> field_4: String (0.0)
> === Request 2
> ::: file1.csv
> lon,lat,id,
> 0.084362378404311,0.08587464990542,"0"
> 0.090601035370249,0.005574551382458,"1"
> 0.074081946277276,0.020574321282505,"2"
> 0.034318505618178,0.034922734033886,"3"
> 0.008330436091964,0.013543226571866,"4"
> Message: 2
> Date: Mon, 31 May 2021 13:41:55 -0700 (MST)
> From: jratike80 <
> jukka.rahkonen@
> To:
> gdal-dev at .osgeo
> Subject: Re: [gdal-dev]
> Message-ID: <
> 1622493715145-0.post at .nabble
> Content-Type: text/plain; charset=us-ascii
> Hi,
> Please add couple of rows from your CSV file. Maybe the lon and lat fields
> are otherwise OK but GDAL does not recognize them to contain numbers but
> perhaps text. You can also check what sort of attributes ogrinfo reports
> with
> -Jukka Rahkonen-
> gdal-dev mailing list
> gdal-dev at .osgeo
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
