[gdal-dev] GDAL Reproject Run as a Batch under QGIS
jratike80 jukka.rahkonen at maanmittauslaitos.fi
Thu Jun 3 13:51:32 PDT 2021
This seems to be a wrong mailing list. Use qgis-users
https://lists.osgeo.org/mailman/listinfo/qgis-user instead or
gis.stackexcange site. Before you write a new mail or question please try to
improve your question a bit. What is not working? Do you know if
reprojecting a whole directory of files is supported or if you are rather
requesting a new feature?
-Jukka Rahkonen-
Mike Stanton wrote
> It is not working. I cannot put any reasonable information into the
> "Reproject" field of the batch job menu that makes it acceptable. What I
> would expect is to point at a folio containing Tiff Files for the input
> and a folio to receive the converted Tiff Files for receiving output that
> might be named the same as the input file. What it appears to expect is
> individual TIFF names. Does anyone have suggestions on how to correct
> this?
> Mike
> gdal-dev mailing list
> gdal-dev at .osgeo
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
