[gdal-dev] Introducing the cogger and godal projects
Even Rouault even.rouault at spatialys.com
Fri Jun 4 09:32:43 PDT 2021
I haven't benchmarked cogger but I'd expect it to be much faster than
gdal_translate -of COG (if your input is GeoTIFF and always properly
tiled and compressed of course!). gdal_translate -of COG uses generic
GDAL API to acquire input data, which implies decompression /
recompression. And in particular, if using input GeoTIFF with lossy
compressed methods such as JPEG or WebP, cogger will avoid adding any
new loss.
Le 04/06/2021 à 18:28, thomas bonfort a écrit :
> I haven't extensively used -of COG (the cogger code actually predates
> the cog driver) but iirc there are at least some cases where it uses
> an intermediate file, which would imply that cogger does offer some
> speedups. I'll let Even confirm...
> Regards,
> Thomas
> Le ven. 4 juin 2021 à 18:14, <Matt.Wilkie at yukon.ca
> <mailto:Matt.Wilkie at yukon.ca>> a écrit :
>     Is cogger specifically for the scenario where your converting a
>     large imagery library that already exists, but isn't cloud
>     optimized? i.e. Does it offer any advantages over the one step
>     `gdal_translate -of cog ...` when starting fresh?
>     Cheers,
>     Matt
>     Geomatics Analyst | Environment | T 867-667-8133 | Yukon.ca
>     Hours: 08:30-16:30, Tue-Wed: Office, Thu-Fri: Remote.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210604/c953b1fb/attachment-0001.html>
