[gdal-dev] gdaladdo bigtiff err but --config BIGTIFF was used
    Even Rouault
    even.rouault at spatialys.com
    Mon Jun 14 12:44:56 PDT 2021
Matt,
You can create external overviews with the -ro switch
Even
Le 14/06/2021 à 21:12, Matt.Wilkie at yukon.ca a écrit :
>> Your initial test.tif file needs to be a bigtiff, i.e. have been
>> created with -co "BIGTIFF=YES". you can then drop the bigtiff
>> config arguments of your gdaladdo call.
> Ahh, thanks Thomas, that indeed is the problem.
> Unfortunately for me it means in this case I'm stuck, as the original is jpeg-tiff and I don't want to pay the penalty of another decompress-recompress cycle to change to big tiff. However at least I know what's going on now.
> -Matt
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
